fubars
Post by fubars on Apr 21, 2021 16:19:49 GMT 1
I'm looking for two high top - bottom carb cables or the entire throttle cable. I can't find any only ones I can find are for low tops 😕
Post by reedpete on Apr 23, 2021 20:59:44 GMT 1
There’s a company that make custom cables that are not expensive given OEM prices. Others will know the name if that’s a consideration
fubars
Post by fubars on Apr 24, 2021 10:01:05 GMT 1
There’s a company that make custom cables that are not expensive given OEM prices. Others will know the name if that’s a consideration do you know the company ? The one I've found is near lincoln but no off the shelf far as I can see.
Post by Chewie01 on Apr 24, 2021 10:06:57 GMT 1
Venhill make custom cables, but you will need to give them the dimensions to make up these cables. www.venhill.co.uk/
Post by reedpete on Apr 24, 2021 11:57:02 GMT 1
Venhill make custom cables, but you will need to give them the dimensions to make up these cables. www.venhill.co.uk/Yep, venhill was the one I was trying to remember...
fubars
Post by fubars on Apr 24, 2021 13:57:39 GMT 1
Venhill make custom cables, but you will need to give them the dimensions to make up these cables. www.venhill.co.uk/Yep, venhill was the one I was trying to remember... That's the problem I don't have any measurements.
Post by reedpete on Apr 24, 2021 13:58:50 GMT 1
I’ll measure for you
fubars
Post by fubars on Apr 24, 2021 14:46:50 GMT 1
Cheers that would help me no end
Post by reedpete on Apr 24, 2021 17:24:00 GMT 1
Total length of cable outside of the splitter to tip of nipple is 30cm, 10 of which is the free inner and 20 is the outer. I don’t know what the dimensions required are inside of the splitter but they just need to suit yours. I have photos if needed for clarification. Just happen to be fiddling with a high top bike at the mo so was easy to do. This all works assuming you have high tops with the correct curved cable guide/top adjuster.
fubars
Post by fubars on Apr 24, 2021 18:57:24 GMT 1
Total length of cable outside of the splitter to tip of nipple is 30cm, 10 of which is the free inner and 20 is the outer. I don’t know what the dimensions required are inside of the splitter but they just need to suit yours. I have photos if needed for clarification. Just happen to be fiddling with a high top bike at the mo so was easy to do. This all works assuming you have high tops with the correct curved cable guide/top adjuster. That's great thanks very much I will see what I can do now if you can post a photo too that would be great 👍
Post by reedpete on Apr 24, 2021 21:57:15 GMT 1
Post by reedpete on Apr 24, 2021 21:57:51 GMT 1
fubars
Post by fubars on Apr 24, 2021 22:39:09 GMT 1
Excellent thank you 😊
