Post by damiensk on Apr 11, 2021 20:21:42 GMT 1
evening,
not sure if this seller is someone on here,
but has anyone fitted one to thier bike?
looks like he has sold a fair few.
mine isnt leaking, but if it may do one day, this could be a quick fix? i know there is another alternative, that i have seen on a few posts
i assume the plastic spacer my need to bit cut down a little?
thanks
Post by oldelsieboy on Apr 11, 2021 20:32:22 GMT 1
evening,
i assume the plastic spacer my need to bit cut down a little? thanks
Contact normanoo4, he sells then a bit cheaper. He also supplies a slightly shorter spacer. rdlccrazy.proboards.com/user/7553OEB
Post by damiensk on Apr 11, 2021 20:46:08 GMT 1
thanks OEB,
buying the spacer would save cutting your own nealrly 40 years old one. was kind of curious if any one had actually fitted one?
Post by shaunthe2nd on Apr 11, 2021 21:21:03 GMT 1
I've fitted a few with no problems on both 4L0's and 4 L1's. Its a good solution. Can't remember name of the seller I used, but look to be very similar to your post.
Post by Chewie01 on Apr 12, 2021 12:28:34 GMT 1
They seem to do the job and are easy enough to fit. You will need to cut down the nylon spacer to make it fit, or get one with a new spacer. Here is a video of one being installed.
Post by damiensk on Apr 12, 2021 22:52:42 GMT 1
spot on, video makes it look easy enough. will save a lot of hassle and time,
thanks
