Post by loctite on Apr 11, 2021 15:33:57 GMT 1
Hi chaps I've dug out some yambits crank seals purchased on separate occasions obviously not used through fear of failure,these were brought as a kit for rd250f and rd400f the ones on the right are both ars the left side ones stator side is ars the other is sfk not sure why they are different but that's what I got rd250f ones I got ten years ago the 400f ones three years ago just wondered which seals fail
Post by Yogi on Apr 11, 2021 15:36:25 GMT 1
I wouldn’t touch any Shambits seals it’s not worth the grief
Post by loctite on Apr 11, 2021 15:57:21 GMT 1
No neither would I but would anyone copy an oil seal,or even worse sell one which is not fit for purpose.i can’t understand who would benefit
Post by liffy16 on Apr 11, 2021 17:17:18 GMT 1
Recent thread on here recently concerning shambits crank seals, not very good and as said not worth the hassle
Post by tony2stroke on Apr 11, 2021 17:22:35 GMT 1
Apparently Yamaha are now getting their ARS seals made in China too, and Yambits is selling the same ones, you want the earlier Jap ones, or ask PJME about his new Jap ARS seals that he has made for own stock, was a thread a couple weeks ago about this.
Post by mikeleflay on Apr 11, 2021 19:37:49 GMT 1
Recent thread on here recently concerning shambits crank seals, not very good and as said not worth the hassle Yes had two sets of yambits seals fail in a matter of minutes, bought some genuine yam ones and bike rjns fine.
Post by 4l04ever on Apr 13, 2021 18:12:19 GMT 1
The ARS seals are the same as OEM Yamaha seals. The original SFK seals did not have the red/brown coating on the inner lips, which the ARS ones do. The latest SFK ones do now have the coating, so should be okay.
Post by JonW on Apr 14, 2021 8:57:33 GMT 1
If Yam buys ARS seals with the lipgloss (coating) from China then I would say that Yam is saying they are fine. I would use them.
Post by tony2stroke on Apr 14, 2021 11:15:06 GMT 1
Only time will give the answer there.
Post by reedpete on Apr 14, 2021 12:10:40 GMT 1
If I bought from Yamaha directly I would have confidence....but let’s take NGK plugs as an example.....since there is clear evidence Yambits don’t understand the importance of material specifications and supply chain control, would you prefer to buy a plug that looks like NGK from them or a authorised regional distributor?.... Just having ARS moulded in the polymer and a lip coated ring....doesn’t make them ARS....I have simply been let down personally by Yambits on enough occasions that I will now never by anything from them that has a critical functional purpose.
Post by midlifecrisisrd on Apr 14, 2021 12:59:57 GMT 1
Totally agree with above
Says NGK on a fake plug
I now only buy plugs from my local bike shop, don't trust any plugs off ebay
Even better if he's been just short of a discount and bought Yam boxed plugs
I said at the beginning of this thread that they could just be copied from an ARS seal
If they are brazen enough to make those copy BMW X5's and that's the legit ones what's the dodgy ones capable of
Post by JonW on Apr 14, 2021 13:40:26 GMT 1
We've said it a million times, only use OEM seals... if its in a Yam bag and from a dealer or trusted supplier it will be fine.
I would not trust a random 'ARS' seal from someone else lip-gloss or not.
Post by liffy16 on Apr 14, 2021 18:59:02 GMT 1
We've said it a million times, only use OEM seals... if its in a Yam bag and from a dealer or trusted supplier it will be fine. I would not trust a random 'ARS' seal from someone else lip-gloss or not. +1 for that the Chinese have no shame they will copy anything and don't care if it's any good or not,doesn't help when the Japanese are out sourcing stuff to China.Try and buy as little as possible from China just from a humanitarian point of view,hard to do though.
