Post by carioca656 on Apr 10, 2021 17:07:46 GMT 1
hi guys any advice on what head gasket to use on a 375 top end ive just bought this oneand not sure if you can get oversize head gasket or not
thanks adie
Post by dave1963 on Apr 10, 2021 17:32:46 GMT 1
I had trouble with gaskets on my fahron 370 ended up getting ron to o ring it
Post by pedheadfred on Apr 10, 2021 21:26:07 GMT 1
I had trouble with gaskets on my fahron 370 ended up getting ron to o ring it Ron is constantly machining for o ring conversion because of this common fault.
Post by beardy on Apr 10, 2021 21:26:56 GMT 1
Mines a 375 and it’s got a standard head gasket and the last time the head was off was back in 1986. Since joining this forum I’ve since learnt the gasket may be intruding into the bore? But it runs fine so I’m leaving it until I need to take the head off again for whatever reason. Doesn’t really help does it?
Post by dave1963 on Apr 11, 2021 11:46:44 GMT 1
The 375 runs dt pistons the same as the 370 found it to be ok on standard bore but once you go up couple of sizes the pistons will catch the head gasket
Post by carioca656 on Apr 11, 2021 15:33:18 GMT 1
So it seems a trip to see Ron is in order or is there anyone else that does this as I know Ron's timescales
Post by oldelsieboy on Apr 11, 2021 16:03:40 GMT 1
So it seems a trip to see Ron is in order or is there anyone else that does this as I know Ron's timescales I think Dave (muttsnuts) offers this service. OEB
