jam911
Post by jam911 on Apr 7, 2021 22:30:45 GMT 1
I have a new front mudguard sticker to apply.
Should I clear coat over the top of after I have applied it and what is the best rattle can clear coat to use ?
Thanks
Post by donkeychomp on Apr 7, 2021 22:35:51 GMT 1
Hycote lacquer. Apply it in warm conditions and use thin coats. It's very good.
Post by JonW on Apr 8, 2021 7:16:02 GMT 1
OEM the decals were not cleared on panels other than the tank...
Post by 4l04ever on Apr 8, 2021 8:06:46 GMT 1
Depends on if you have a laminated decal or non-laminated. The laminated ones need no lacquer.
jam911
Post by jam911 on Apr 8, 2021 8:33:46 GMT 1
It came from Norbo and it looks original so I am not sure if it is laminated or not, I expect not.
I think if the OEM were not clear coated I will just stick it on.
Post by botty on Apr 8, 2021 10:03:43 GMT 1
I have used the product on the left for this belly pan. It is a 2K spray but is not 100% petrol proof. Ok if you wipe off straight away. The one on the right is 2K has the agitator with the hardener which is petrol proof and a much better system
Post by JonW on Apr 8, 2021 13:53:44 GMT 1
Be VERY wary of 2k paint in cans... most of this stuff has nasties in it that can kill you stone dead if youre one of the people who is effected badly by the chemicals. Always wear a special mask for this stuff. Ive said before but at my paint place one of the guys tells the story of a bloke who had a can made up, nipped outside to spray a tester and didnt come back. The ambulance crew pronounced his dead on their doorstep... be careful.
Post by oldelsieboy on Apr 8, 2021 17:16:43 GMT 1
I have a new front mudguard sticker to apply. Should I clear coat over the top of after I have applied it and what is the best rattle can clear coat to use ? Thanks ["anorak on"] LC's with three stripe decals do not have a stripe on the front mudguard. ["anorak off"] OEB
Post by stusco on Apr 8, 2021 17:23:04 GMT 1
Ive used the pro xl bought a suitable mask as my lungs are crap as it is ,good stuff though
Post by abar121 on Apr 8, 2021 17:32:34 GMT 1
I've also used the Pro XL 2k in a can, with a specific mask.
But you don't really need that for the mudguard, only the fuel tank to avoid damage when filling up.
Unless you do the porn star splash it all over..
jam911
Post by jam911 on Apr 8, 2021 17:39:16 GMT 1
Thanks for the tips guys. No clear coat it is.
