Post by noonster on Apr 5, 2021 19:44:34 GMT 1
rd350lc head light wont switch on
before i stripped the bike it worked fine side light works. rear light works
no front light.
got a spare bulb,still nothing. got spare switches,nothing all fuses ok everything works on the bike except front headlight,high beam and flasher.
any ideas before i start going through the wiring diagram
Post by oldelsieboy on Apr 5, 2021 19:50:14 GMT 1
rd350lc head light wont switch on before i stripped the bike it worked fine side light works. rear light works no front light. got a spare bulb,still nothing. got spare switches,nothing everything works on the bike except front headlight,high beam and flasher. any ideas before i start going through the wiring diagram Try the fuse. OEB
Post by noonster on Apr 5, 2021 20:19:02 GMT 1
Thank you for the response.
I forgot to mention the 10amp fuse is ok ignition 20 amp also ok
Post by stusco on Apr 5, 2021 20:32:31 GMT 1
You need a multi meter
Post by Chewie01 on Apr 5, 2021 20:33:09 GMT 1
I think the correct course of action is to refer to the wiring diagram and probe with a multi-meter, whilst swearing at it repeatedly. The searing doesn't help you find the fault but it does make you feel better about it.
Post by 4l04ever on Apr 6, 2021 10:28:30 GMT 1
Check the earth/ground connection to the bulb.
haj
Post by haj on Apr 6, 2021 11:55:58 GMT 1
Measure the voltage both on one side of the fuse and other side.. I had voltage drop in the fuse holder on mine. It took me a couple of hours to diagnose since I had already checked the fuse..
Post by shaunthe2nd on Apr 6, 2021 12:32:31 GMT 1
I had something similar ^^^^^. I pulled all the wires away from each other in the fuse box and sorted it. Must have been some sort of a short.
Post by noonster on Apr 7, 2021 17:55:51 GMT 1
found the 2nd fuse in from the right,head light circuit is blowing the fuse. straight away. so must have a short some where.
unplugged switches,still blows the fuse if i leave the fuse out, everything works again except the head light.
thought i found it wit a badly jointed red wire,twisted together. soldered it together,still blows the fuse
wondering if i have a broken wire, going upto the plugs next to the coil,for switches to plug into
Post by steeley on Apr 11, 2021 8:28:12 GMT 1
Hmmm , power going to earth . You will now need to check the wiring for breaks / insulation worn through . Do lots of swearing as has already been mentioned . I hate electrics .
Post by JonW on May 6, 2021 5:00:14 GMT 1
just take your time and work through the connections, pull them apart and clean them while refering to the wiring diagram.
If that is not it, check the inside of the switch.
You will find the issue I am sure, take your time and relax into it. swearing is optional, it helps but will never fix the issue.
