Post by joshready on Apr 3, 2021 3:17:58 GMT 1
Should the gearbox shaft beatings have any up/down movement? Thanks
Post by huxley on Apr 3, 2021 7:13:16 GMT 1
I don,t think it should have any movement at all.
Post by Chewie01 on Apr 3, 2021 8:00:07 GMT 1
No. It shouldn't have any movement in any direction, other than rotational. Sadly it's time for the engine to come out and a full strip down to change it.
Post by joshready on Apr 3, 2021 8:05:14 GMT 1
No. It shouldn't have any movement in any direction, other than rotational. Sadly it's time for the engine to come out and a full strip down to change it. Just split it today. Gearbox bearings are toast then. Crank and big ends are spot on but i will be upgrading the crank. Thanks guys.
Post by huxley on Apr 3, 2021 16:03:24 GMT 1
If you have split the cases I would change all the bearings you can
