Post by chippy348 on Mar 31, 2021 20:57:14 GMT 1
So just sorting out the plating for my 85 57V RD350 YPVS F1
So whats olive green and what is Zinc plated silver and is anything plated yellow passivate
I think the tie bars and all engine bolts are olive,
Not so sure on wheel and swing arm spinal same for all the suspension linkage
Any help would be much appreciated
Post by midlifecrisisrd on Mar 31, 2021 21:36:39 GMT 1
The 3 rear suspension bolts, the seat catches, nuts, tail light nuts/washers and seat latch screws are yellow
Probably forgot something
Disc bolts and caliper bolts are olive unlike the other ypvs
Tie bar bolts are zinc/clear
Tie bar brackets are olive
Post by midlifecrisisrd on Mar 31, 2021 21:39:27 GMT 1
Tail light bracket bolts, oil tank bolts, servo screws, cdi screws
All yellow
Post by midlifecrisisrd on Mar 31, 2021 21:43:17 GMT 1
Post by chippy348 on Mar 31, 2021 21:49:50 GMT 1
Going to look at that now thanks
Post by Yogi on Mar 31, 2021 21:56:02 GMT 1
Front brake line to fork brackets are olive too
Post by midlifecrisisrd on Mar 31, 2021 22:01:41 GMT 1
Brake banjo bolts are olive
Back to you Matt
Tag team 😆
Post by chippy348 on Mar 31, 2021 22:16:14 GMT 1
The 3 rear suspension bolts, the seat catches, nuts, tail light nuts/washers and seat latch screws are yellow Probably forgot something Disc bolts and caliper bolts are olive unlike the other ypvs Tie bar bolts are zinc/clear Tie bar brackets are olive Steve Confusing as i got some s/h tie bars and the bolts were olive, i got some new ones from Yam some are olive some zinc clear looking at your N1 resto the wheel and swing arm spindles are clear zinc
Post by Yogi on Mar 31, 2021 22:18:33 GMT 1
Clocks,light bracket and all fork bolts are olive 😂
Post by Yogi on Mar 31, 2021 22:20:10 GMT 1
Back to you Stevo 🤣
Post by midlifecrisisrd on Mar 31, 2021 22:20:11 GMT 1
Rear master cylinder bolts and side stand bolt are olive
Post by Yogi on Mar 31, 2021 22:21:47 GMT 1
Gear shift and brake pedal are olive
Post by chippy348 on Mar 31, 2021 22:25:56 GMT 1
just thought of something else, brake caliper bolts
Ones that hold the caliper together Ones that hold the caliper to the forks / rear bracket
Post by midlifecrisisrd on Apr 1, 2021 8:27:10 GMT 1
just thought of something else, brake caliper bolts Ones that hold the caliper together Ones that hold the caliper to the forks / rear bracket Both olive Centre stand bolts were yellow 😁 Steve
