Post by geoffers997 on Mar 30, 2021 11:35:58 GMT 1
Hi all, Just seen this: Simoniz Gloss Black Engine Enamel Spray Paint 500ml, £6.69 at EuroCarParts
Seems a cheap price.
Post by abar121 on Mar 30, 2021 11:46:23 GMT 1
It's good stuff!
Post by freddie19 on Mar 30, 2021 23:05:20 GMT 1
Cheers mate,
just picked up a can today, bargain!😀👍
Post by kirkhd on Mar 30, 2021 23:31:29 GMT 1
Does anyone know if the vht is gloss or matt?
Post by freddie19 on Mar 31, 2021 1:24:28 GMT 1
It's in the title mate ........it's Gloss!👍
Post by kirkhd on Mar 31, 2021 17:01:51 GMT 1
It's in the title mate ........it's Gloss!👍 Cheers but i was enquiring about the finish of the VHT paint that they do not the Engine Enamel as it's the same price and fuel spills done damage it.
Post by jon on Mar 31, 2021 17:47:04 GMT 1
Am I right in saying it’s a good match to OEM for YPVS heads and cylinders?
Or is it too shiney?
Post by freddie19 on Mar 31, 2021 18:44:51 GMT 1
YPVS head is definitely gloss but I'm just not too sure whether the cylinders were originally gloss or satin finish!
On my low miles original RZ the cylinders are definitely not gloss, much more of a satin finish.
Having said that, when I look at the OEM finish on my LC2 cylinders by flipping them over and looking at the paint on the reed valve intakes it definitely looks more gloss.
Perhaps with time and heat the original gloss finish does degrade more to a satin/ Matt look!
I have this dilemma myself as I'm just not sure whether to paint my LC2 cylinders gloss or satin. 🤔
Simoniz also do a satin black VHT paint, although it doesn't say it's an engine enamel made specifically for use on engines! It's Simoniz Tough Black Satin.
Decisions, decisions!😀
Post by jon on Mar 31, 2021 18:51:40 GMT 1
Yes exactly.
I have a YPVS engine that’s not been messed with and the cylinders are a cross between gloss and satin.
Post by freddie19 on Mar 31, 2021 19:03:11 GMT 1
Cheers Jon.👍
Post by midlifecrisisrd on Mar 31, 2021 20:35:22 GMT 1
1ua cylinders were satin
I've had a NOS 31k cylinder and it was gloss same as the head
Not like the glass finish of Hycote/Simoniz but deffo not satin
The high gloss does tone down a bit with use/weathering
31k bikes also had gloss clutch case where 1ua was satin again
The paint does deteriate on the cylinders
Post by freddie19 on Apr 1, 2021 19:15:10 GMT 1
So I finally dug out one of my NOS 31K cylinders off the top of my wardrobe, surrounded by Shoei boxes so not an easy job!,🙄 So looking at the original Yamaha black finish it's definitely a glossy black, but not a really high gloss. I want to say semi gloss but I think it's a bit shinier than that! Here are a couple of pictures, what do you guys reckon?🤔 So now I'm thinking I'm gonna paint my LC2 cylinders with the the Simoniz Gloss Enamel and give it a blast with the heat gun to speed up the drying and hopefully dull down the gloss just a touch!😀
Post by midlifecrisisrd on Apr 1, 2021 19:29:56 GMT 1
So I finally dug out one of my NOS 31K cylinders off the top of my wardrobe, surrounded by Shoei boxes so not an easy job!,🙄 So looking at the original Yamaha black finish it's definitely a glossy black, but not a really high gloss. I want to say semi gloss but I think it's a bit shinier than that! Here are a couple of pictures, what do you guys reckon?🤔 So now I'm thinking I'm gonna paint my LC2 cylinders with the the Simoniz Gloss Enamel and give it a blast with the heat gun to speed up the drying and hopefully dull down the gloss just a touch!😀 Think that's the best way to describe it "Not high gloss" With the Hycote I tend to paint it, let it dry a little then mist over from a bit of a distance. Tends to knock the gloss off and give that slight texturwd finish Steve
Post by freddie19 on Apr 1, 2021 19:40:50 GMT 1
Yeah, I was also thinking about doing that as an option also Steve, I remember you mentioning it before!
Yes, a final light mist coat from a distance will definitely give it a less glossy, slightly satin finish.👍
Post by midlifecrisisrd on Apr 1, 2021 19:45:26 GMT 1
It seems to work 😁
Post by freddie19 on Apr 1, 2021 19:56:13 GMT 1
Looking good Steve.....but it does look a touch extra glossy to me......but I am a picky old bugger me!😩🤣🤣🤣
But I think I'm preferring that look to my original idea of painting mine satin.
Hopefully I'll get them painted soon then I can compare the finish to my NOS cylinders!👍
