Top speed
Mar 30, 2021 8:51:00 GMT 1
via mobile
Post by joshready on Mar 30, 2021 8:51:00 GMT 1
Hypothetical one, what would one think an ok tuned( projected 60ish hp) Rd350lc could run on a race track with a 1km downhill straight with a medium bend on and fast corner off? Eastern Creek btw. 17/41 17inch wheels. Cheers
Post by steve63 on Mar 30, 2021 17:44:11 GMT 1
Hypothetical one, what would one think an ok tuned( projected 60ish hp) Rd350lc could run on a race track with a 1km downhill straight with a medium bend on and fast corner off? Eastern Creek btw. 17/41 17inch wheels. Cheers Cadwell has two straights. One pretty flat with a 50mph corner onto it and 85 ish at the end one (Park) with 60mph on that dips down and then back up with 40/50 corner off. The first is maybe 0.5 k and the second maybe 0.6/0.7k long. My RGV250 VJ21 is standard and has 50.7hp. On standard gearing I was just using top at the end of the second straight and seeing maybe just 110mph on the speedo. When I say seeing I mean watching the video afterwards. There's no way I can watch the speedo and hit my braking marker . I could actually get away with leaving it in 5th but it was hitting about 11,000rpm. True speed is about 104/5 mph measured with my TomTom watch or Garmin GPS Virb. Last time I was there I changed from 15 to 14 front sprocket and even though I got into 6th earlier the top speed didn't really improve. Unless I can get onto them a lot quicker or take the corners at the end quicker or brake later (which is not going to happen) I think I've reached my particular limit. My last time there ended at A&E, that's how I know I seem to remember my proddy YPVS doing 110/120 on Park back in the 80's but that was speedo speed and from my fading memory I think we pretty much used 17/39 standard gearing most places. I don't know how the wheel size effects things but it would be more about tyres than wheel diameter. So say 160/60/17 would be 60% of 160 =96mm. 2 x 96 = 192 + 17" (432mm) = 624mm diameter. 110/80/18 (std. LC) would be 80% of 110 =88mm. 2 x 96 = 176 + 18" (457mm) = 633mm. diameter. So a decrease of 9mm dia or 28mm decrease in circumference. Not as much as some people think Please no one check my maths
Post by midlifecrisisrd on Mar 30, 2021 17:56:26 GMT 1
On 17/41 gearing it will be about 110 flat out if it will pull to the red line
Post by abar121 on Mar 30, 2021 18:05:45 GMT 1
My TZR250 race bike with 56bhp pulled 11k on the tach on the Revett straight at Snetterton, pretty much the longest straight on a UK track here.
That worked out to 126mph based on the gearing, but the tach is a bit optimistic, so I would guess 115 or so.
I remember following the quickest BEMSEE LC rider around there and we were dead even on the straight. He must have had more power to compensate for being naked.
I ran shorter gearing at Cadwell for sure.
Post by steve63 on Mar 31, 2021 12:36:35 GMT 1
My TZR250 race bike with 56bhp pulled 11k on the tach on the Revett straight at Snetterton, pretty much the longest straight on a UK track here. That worked out to 126mph based on the gearing, but the tach is a bit optimistic, so I would guess 115 or so. I remember following the quickest BEMSEE LC rider around there and we were dead even on the straight. He must have had more power to compensate for being naked. I ran shorter gearing at Cadwell for sure. Sounds like standards have dropped dramatically. back in my day full leathers were compulsory. Even zip together weren't allowed....................
Post by headcoats on Mar 31, 2021 12:49:38 GMT 1
My LC looks 100 mph while standing at the traffic lights LOL
Post by steve63 on Mar 31, 2021 13:02:27 GMT 1
My TZR250 race bike with 56bhp pulled 11k on the tach on the Revett straight at Snetterton, pretty much the longest straight on a UK track here. That worked out to 126mph based on the gearing, but the tach is a bit optimistic, so I would guess 115 or so. I remember following the quickest BEMSEE LC rider around there and we were dead even on the straight. He must have had more power to compensate for being naked. I ran shorter gearing at Cadwell for sure. The 31K I raced had won a few races at Snetterton. Not with me on it unfortunately. The guy I bought it off said you don't win there unless you have a fast bike. I only went to Snett once and that was as a helper/hanger on for a guy riding a 500 Velocette in a classic series in about 1984. I had made him an open megaphone exhaust for it. I guess they never had noise limits then We never left the pits and I had no idea were the circuit went at all. I do remember it taking an age to get there in a 20 year old Transit with a top speed of 45. The opinion in 1985 was that a good valve will have about 60hp. I went head to head with a TZ250 E or F and we were pretty equal side by side on Park Straight so sounds about right. I remember going round Mallory on the YPVS and a guy called Martin Kilby on an LC being 6" off my back end all the way around. It tends to put you off a bit The Mark III Gamma came out and that was it for me really. The end of a very mediocre career.
Top speed
Apr 1, 2021 10:26:25 GMT 1
via mobile
Post by joshready on Apr 1, 2021 10:26:25 GMT 1
On 17/41 gearing it will be about 110 flat out if it will pull to the red line Steve Does the lack of aero really affect them by 100mph?
Top speed
Apr 1, 2021 11:10:15 GMT 1
via mobile
Post by midlifecrisisrd on Apr 1, 2021 11:10:15 GMT 1
It will have an effect but it should still pull past 100
If it didn't effect it then moto3 bikes would be naked lol
Post by joshready on Apr 1, 2021 12:11:10 GMT 1
Ha, More power and revs then!
Post by steve63 on Apr 2, 2021 10:37:00 GMT 1
On 17/41 gearing it will be about 110 flat out if it will pull to the red line Steve Does the lack of aero really affect them by 100mph? You kidding??? 😁 I used to get on the tank on my FSIE to get from 41 to 48mph. 100mph was just a distant dream. We used to all be flat on the tank side by side on our RD200's trying to pass each other at 85 😁
Post by JonW on Apr 3, 2021 5:03:28 GMT 1
Josh, have you asked the PCRA boys on their Fb forum? plenty of them have run an LC over the years at EC and will know.
