Post by headcoats on Mar 28, 2021 11:16:42 GMT 1
Thanks to Andy748 I now have some RGV250 top and bottom yokes , hand delivered too
How do I remove the ignition switch as it has some sort of rivets holding them in ?
Post by midlifecrisisrd on Mar 28, 2021 11:20:20 GMT 1
It will be shearing nuts
The head snaps off when tight and is for security
I usually run a drill bit into the head then hammer a torx bit in
Usually enough loosen it
stasky
Post by stasky on Mar 28, 2021 18:53:14 GMT 1
dremel or hacksaw a slot in them,then remove with a screwdriver or impact driver if there tight
