Post by joshready on Mar 27, 2021 0:06:31 GMT 1
Anyone have experience with an EGT probe and which one does the job? Mounted about 6 x bore size from piston face too? Cheers Josh
Post by bare on Mar 27, 2021 17:47:07 GMT 1
EGT gives V useful info . But Best used where one can readily adjust Air fuel ratios... In use.. Like in a Cessna.
Post by joshready on Mar 28, 2021 0:30:36 GMT 1
Im using it for the track. Little 350 will be on the pipe a lot. Only have a few rebores left and its a nice safety guage.
Post by 4l04ever on Mar 29, 2021 8:43:29 GMT 1
I have used them in the past. They are basically just Type-K thermocouples. Mine have welded in bungs in the downpipes. They were difficult to correlate temperature to mixture, as was affected by load too. The temperature could be high or low depending what was going on. In the end I took them off as never saved a blow-up.
I started looking at detonation detection equipment, but not completed it yet.
Go-kart AFR systems might be worth a look too.
Post by marrcel on Mar 29, 2021 16:09:14 GMT 1
Here is some deto info
