Tsa pipes
Mar 25, 2021 15:12:16 GMT 1
via mobile
Post by dave1963 on Mar 25, 2021 15:12:16 GMT 1
Hi i have got some tsa pipes to put on my ypvs do i need to up jet. I am running jim lomas pipes at the moment w Thanks dave
Post by Chewie01 on Mar 25, 2021 16:18:52 GMT 1
Did you get the ones that were advertised on ebay recently? They looked in good condition under the thick layer of dust.
Tsa pipes
Mar 25, 2021 19:07:38 GMT 1
via mobile
Post by dave1963 on Mar 25, 2021 19:07:38 GMT 1
No got stainless ones off ebay about 6 weeks ago
Post by 4l04ever on Mar 27, 2021 1:02:35 GMT 1
Each bike varies, but usually yes for TSA pipes. My 3XV ended up going up 6 sizes on the mains going from Nikon to TSA pipes.
Post by mellow on Mar 30, 2021 18:05:33 GMT 1
just to throw a spanner in the works i have TSA Pipes. Standard engine. Both snorkels removed from airbox, standard jets.........and it is running fine fuel wise, in fact its still richening when reaching peak power
Post by hoist1 on Mar 30, 2021 18:24:01 GMT 1
just to throw a spanner in the works i have TSA Pipes. Standard engine. Both snorkels removed from airbox, standard jets.........and it is running fine fuel wise, in fact its still richening when reaching peak power Sounds good in your vids. Hmm, in fact it’s cost me to get a ypvs to go with the 4LO. Result
Tsa pipes
Mar 30, 2021 18:30:04 GMT 1
via mobile
Post by dave1963 on Mar 30, 2021 18:30:04 GMT 1
Hi thanks for posts i will get it on the dyno when i have put the new topend on was just looking for a starting point to run it in first Thanks dave
Tsa pipes
Mar 30, 2021 20:29:13 GMT 1
via mobile
Post by mellow on Mar 30, 2021 20:29:13 GMT 1
That's the best option to know for sure👍😎
Tsa pipes
Mar 30, 2021 20:31:24 GMT 1
via mobile
Post by mellow on Mar 30, 2021 20:31:24 GMT 1
Sounds good in your vids. Hmm, in fact it’s cost me to get a ypvs to go with the 4LO. Result Ha ha thank you😁👍😎🏍
Post by zig on Mar 30, 2021 20:49:46 GMT 1
I have kenny's TSA stainless on my 4l0 with airbox removed running RamAir pods and up 2 sizes in main
great pipes and quality , hope this helps
ZiG
Post by muttsnuts on Mar 30, 2021 21:16:32 GMT 1
Hi Dave,
most of the YPVS's with Kenny's pipes on that I've done have gone up 2 sizes on the mains, I've had a couple that ran fine on standard, but most have gone up, have had one that went down on the main to fuel right, but that was an exception
HTH
Post by marrcel on Mar 30, 2021 22:56:16 GMT 1
Hi Dave, most of the YPVS's with Kenny's pipes on that I've done have gone up 2 sizes on the mains, I've had a couple that ran fine on standard, but most have gone up, have had one that went down on the main to fuel right, but that was an exception HTH And that was with standard airbox with all the baffles and ducting???
Post by muttsnuts on Mar 31, 2021 21:06:25 GMT 1
Hi Dave, most of the YPVS's with Kenny's pipes on that I've done have gone up 2 sizes on the mains, I've had a couple that ran fine on standard, but most have gone up, have had one that went down on the main to fuel right, but that was an exception HTH And that was with standard airbox with all the baffles and ducting??? yes
Tsa pipes
May 2, 2021 18:17:26 GMT 1
via mobile
Post by dave1963 on May 2, 2021 18:17:26 GMT 1
I went to fit the pipes today the n/s left one hits on the lower dogbone nut and the side stand spring pin . Anyone else had this problem .
avb
andys vapour blasting
Post by avb on May 2, 2021 19:40:13 GMT 1
turn th ebolt round in the dog bone.nut should be the other side
Tsa pipes
May 3, 2021 15:03:48 GMT 1
via mobile
Post by dave1963 on May 3, 2021 15:03:48 GMT 1
Thanks avb Turned bolt round and it fits still touching side stand but have got a triumph one comming so will modify it Thanks dave
avb
Post by avb on May 3, 2021 15:07:43 GMT 1
i also had to give a tap with a hammer on exhaust for a bit more clearance
Post by tsa on Jun 15, 2021 15:10:34 GMT 1
The stand issue is you have to much slop in your stand when in the up position.
Post by dave1963 on Jun 15, 2021 20:50:24 GMT 1
The stand issue is you have to much slop in your stand when in the up position. I have fitted the new stand now no problems
