Post by kirkhd on Mar 23, 2021 22:22:41 GMT 1
I'll be passing my local Yam Dealer on Friday so was thinking of calling in to see if they stock the oil seals require for a 31K crankcase rebuild. Below is the list and Part Number i've put together and wondered if someone could see if they are correct or any missing?
93103-10113(No Longer Available?) - Water pump - Replacement 93103-10011
93101-10002 - oil pump 93101-20048 - Kick Start 93102-17004 - Clutch 93102-35054(No Longer Available?) - Gearbox - Replacement 93102-35109
93101-12004(No Longer Available?) - Gear Shift - Replacement 93102-12321
Post by JonW on Mar 23, 2021 23:04:05 GMT 1
Post by kirkhd on Mar 23, 2021 23:31:14 GMT 1
I got them off rd350lc.net/ however the water pump seal is different from the site you listed?
Post by shaunthe2nd on Mar 23, 2021 23:46:38 GMT 1
They look correct against my list of recent parts bought for my 31k engine build.
Post by kirkhd on Mar 23, 2021 23:51:09 GMT 1
Looks like the water pump is different on both site but they have both been superseded with the same number on further investigation.
Post by JonW on Mar 24, 2021 0:27:07 GMT 1
you can also check Fowlers and CMSNL they also have online parts books so do all the supersceeding.
