Post by malc888 on Mar 21, 2021 21:15:16 GMT 1
Hi All,
probably a familiar story, took the bike apart 20 years ago and have forgotten how some of it goes back together!
I rebuilt the engine completely and am a bit worried that I’ve misplaced a ball bearing for the clutch as now it’s back in the frame I can’t get the clutch lever to operate the clutch at all. Neither the Haynes manual or the workshop manual show a ball bearing on the cable/left side of the engine but both the end of the push rod and the end of the adjuster screw seem to be indented to accept a ball bearing. Could someone please confirm whether there is a ball this side of the clutch as well as the other as I can’t think of another reason why I’m not able to get any actuation at all.
thanks in advance - Malcolm
Post by dusty350 on Mar 21, 2021 21:29:56 GMT 1
Hi Welcome to the forum. Lc engine I presume ? There is a ball bearing in the actuator arm on the left case on the aircooled and Lc bikes. It's sealed inside so you cant lose it. The pushrod should have a ball bearing at the clutch end. If it's a Pv, just one ball bearing at the clutch end. Dusty
Post by malc888 on Mar 21, 2021 21:34:27 GMT 1
Hi Dusty,
Thanks for the quick reply! Yes 4lo engine. That makes perfect sense and is a bit of a relief even though I’ve lost the ball bearing as the alternative is that I’ve messed up the clutch some other way. Annoying that neither Haynes nor the workshop manual show it though. Will have to see if Norbo stocks them. Thanks again!
Post by dusty350 on Mar 21, 2021 21:51:09 GMT 1
Norbo may well have it. If not, the part number is 93505 16006. 30p from Fowlers, although they are showing as no stock -backorder . Dusty
Post by malc888 on Mar 21, 2021 22:20:29 GMT 1
Thanks again! This place is great! Will post some pictures when rebuild is further on!
Malcolm
Post by chrisg on Mar 21, 2021 22:58:40 GMT 1
Im sure that I read recently that there is a dimension for the push rop with the ball bearing fitted, so if your measures different, bingo!
Post by Gitram on Mar 21, 2021 23:30:14 GMT 1
pretty sure they are the same size as the ones out of a pushbike bottom bracket, 1/4 inch or thereabouts..
marti
Post by malc888 on Mar 21, 2021 23:39:56 GMT 1
Im sure that I read recently that there is a dimension for the push rop with the ball bearing fitted, so if your measures different, bingo! don’t suppose you recall where you saw the dimension? I’m obviously looking at the wrong sources cos I can’t find anything that references the ball bearing at all.
Post by oldelsieboy on Mar 22, 2021 19:40:09 GMT 1
Im sure that I read recently that there is a dimension for the push rop with the ball bearing fitted, so if your measures different, bingo! don’t suppose you recall where you saw the dimension? I’m obviously looking at the wrong sources cos I can’t find anything that references the ball bearing at all. The ball is simply a 5/16" ball bearing, available from many different outlets. OEB
Post by earthman on Mar 23, 2021 8:44:53 GMT 1
don’t suppose you recall where you saw the dimension? I’m obviously looking at the wrong sources cos I can’t find anything that references the ball bearing at all. The ball is simply a 5/16" ball bearing, available from many different outlets. OEB I'm wondering if the OEM one were hardened or not? Something to keep in mind if looking to source from another outlet.
Post by chrisg on Mar 23, 2021 11:12:24 GMT 1
Im sure that I read recently that there is a dimension for the push rop with the ball bearing fitted, so if your measures different, bingo! don’t suppose you recall where you saw the dimension? I’m obviously looking at the wrong sources cos I can’t find anything that references the ball bearing at all. Found it. The pushrod should be 46mm approx from the casing with the ball bearing.
Post by malc888 on Mar 23, 2021 12:17:21 GMT 1
Thanks all! I'll look for something appropriate as a replacement.
Post by 4l04ever on Mar 23, 2021 22:52:49 GMT 1
