Post by wonkywheel on Mar 21, 2021 16:49:24 GMT 1
MK2 with 10W carb, getting tricky to start. With choke on, it often dies on me, as soon as I rev out. In fact it won’t rev out, just goes... warp warp warp.... Then hard to start. Once warmed up it’s starts to Rev out. Float heigh set correct and carb recently cleaned, but in the past has been spilling out petrol through the overflow. It’s although it’s flooding. Any thoughts....
Post by brigitte on Mar 22, 2021 19:59:44 GMT 1
Did you clean the starter jet which sits in the float bowl?
Post by wonkywheel on Mar 24, 2021 20:12:46 GMT 1
Did you clean the starter jet which sits in the float bowl? Thanks. Good point. To be honest, when I get the time, I’m going to strip the whole carb and start again.
