ahthud
Post by ahthud on Mar 20, 2021 16:20:37 GMT 1
Just fitted my new Allspeeds to my hybrid and it looks like I'm going to have to relocate the sidestand spring as the frame lug that holds the spring is clashing. Not wanting to reinvent the wheel and knowing this has been done before, could anyone give me any advice/hints on relocating it (alternative sidestands, how you dealt with the cutout switch etc) thanks in advance. ๐
Post by Yogi on Mar 20, 2021 16:49:46 GMT 1
Hi mate The easiest way is to get one of these www.ebay.co.uk/itm/233711436343Slide a washer between the claw as itโs slightly wider Drill and tap a bolt on the outside to hook the triumph spring on and cut the piece off that juts out at the top of the stand Also you have to use the Triumph bolt or similar Matt ๐ป
ahthud
Post by ahthud on Mar 20, 2021 18:53:27 GMT 1
Cheers Matt ๐๐
Post by Yogi on Mar 20, 2021 18:54:04 GMT 1
Hereโs one fitted to an lc but itโs the same for ypvs
Post by Yogi on Mar 20, 2021 19:02:06 GMT 1
Hereโs one on my rs build Matt ๐ป
