Post by scubajas on Mar 16, 2021 19:43:21 GMT 1
Tried to remove swing arm bushes today , I think they are welded in
Any tips for getting these out please
Have tried knocking one bush out from the other side but would budge
Bigger hammer ??
Post by Yogi on Mar 16, 2021 19:49:44 GMT 1
Blind bearing puller and warm the swinger whilst pulling
Post by midlifecrisisrd on Mar 16, 2021 19:50:30 GMT 1
Yes, bigger hammer, they will eventually start moving
Post by huggy76 on Mar 16, 2021 19:52:19 GMT 1
Are we talking about the link arm bushes? If so use a socket to drift them out.
Post by Yogi on Mar 16, 2021 19:52:24 GMT 1
Heat is your friend 🥵
Post by midlifecrisisrd on Mar 16, 2021 19:55:03 GMT 1
I was assuming early bronze pivot bushes
Post by Yogi on Mar 16, 2021 19:59:03 GMT 1
I was assuming early bronze pivot bushes Steve +1🤪
Post by scubajas on Mar 16, 2021 20:11:37 GMT 1
steel bushes absolutly solid
will try a puller
Post by steeley on Mar 16, 2021 20:17:28 GMT 1
Lump hammer and a decent steel drift and a large piece of wood .
Post by scubajas on Mar 16, 2021 20:35:38 GMT 1
where does the wood come in
Post by shaunthe2nd on Mar 16, 2021 21:18:26 GMT 1
If the frame is anything to go by I assume the powder coater painted them in as well which won't help.
I assume you are aware that the swing arm link element its made of 3 parts, the through shaft, an inner bush/shaft that runs full width, and then 2 outer bushes, one per side, approx 40mm long from memory. The original outer bushes were made from a plastic material, often replaced with bronze ones.
Just thought I'd mention this as may help when you know what you are trying to drift out!
Post by shaunthe2nd on Mar 16, 2021 21:19:10 GMT 1
where does the wood come in You hit the painter with the wood! lol
Post by scubajas on Mar 16, 2021 23:17:08 GMT 1
If the frame is anything to go by I assume the powder coater painted them in as well which won't help. I assume you are aware that the swing arm link element its made of 3 parts, the through shaft, an inner bush/shaft that runs full width, and then 2 outer bushes, one per side, approx 40mm long from memory. The original outer bushes were made from a plastic material, often replaced with bronze ones. Just thought I'd mention this as may help when you know what you are trying to drift out! Yes trying to move the outer bushes Will apply heat and a lump hammer tomorrow hopefully that will do it
Post by st66 on Mar 17, 2021 21:35:19 GMT 1
If all else fails a long hacksaw blade and carefully cut two grooves one at six o'clock the other at four o clock not as far through to the alloy of the arm and split it with a small chisel it will relive the tension in the outer shell and drop out but do it slowly only want about 2 mm deep cuts max,, be brave and don't go wild with the hacksaw
Post by scubajas on Mar 17, 2021 23:03:09 GMT 1
If all else fails a long hacksaw blade and carefully cut two grooves one at six o'clock the other at four o clock not as far through to the alloy of the arm and split it with a small chisel it will relive the tension in the outer shell and drop out but do it slowly only want about 2 mm deep cuts max,, be brave and don't go wild with the hacksaw Thanks, can’t get them to budge with heat and punch
Post by st66 on Mar 18, 2021 19:25:54 GMT 1
No worrys mate donne this for years on stubon outer Bush shell it works a treat as releases the preasure and basically you give it space to collapse in on itself and it drops out
Post by jon on Mar 18, 2021 19:37:41 GMT 1
Sorry, not that this will help you, but I have machined two half circle bushes for drifting things like this out. You drop one half in, then the other and centre them. You can see an RGV swingarm drift in the last pic top row, second from left. rdlccrazy.proboards.com/post/496513/threadJon
Post by Trent on Mar 22, 2021 10:41:23 GMT 1
Just had this on a Kawasaki Triple, in the end I carefully hacksawed the flange of the plastic outer stepped bush. This left the steel inner bush protruding about 1/8 inch. Plenty of heat and pounded it back through using a stepped bush driver from a kit I bought ($23 Amazon). Once I got the steel inners out the outers were removed with large bronze drift and heat again. I got bronze replacements as the OEM Plastic crap didn't impress me. To fit them don't ever pound them in. I heated the swingers a bit and pressed them in with 1/2 in steel threaded rod and thick washers and nuts either end (A few bucks at Home Depot). Went in like butter. The problem with bronze is to get the steel bushes in you will probably have to ream them. I bought a 27/32-29/32 adjustable reamer ($24 on internet)and the bushes fit in perfectly after a couple of light cuts. A job I was going to leave as they were seized but not all that worn but made me anxious. So glad its all done properly and ready to go.
