Post by noonster on Mar 16, 2021 15:43:37 GMT 1
can someone measure please how much the peg on the stand sticks out please where the spring attaches to
from stand to out side edge of the dome bit,wondering if i could cut one of my spare lc350 side stand if its the right length
Post by stuartadi on Mar 16, 2021 19:28:16 GMT 1
Hi, Just measured the the pin on my Rd400 and it is 20 mms long including the domed head. Comparing it to the stand on my 31K LC, the 400 is a lot chunkier steel rod, 8mms in diameter so don't think the LC peg would be suitable. I assume the 400 stand is a heavier item because it's a heavier bike and has a stronger spring. I would have thought it would be easy to turn a peg from steel bar if you have a centre lathe, or ask a local engineering firm to do it.
Post by noonster on Mar 16, 2021 20:52:11 GMT 1
thank u
Post by noonster on Mar 17, 2021 9:27:26 GMT 1
i have just measures the peg on my spare lc350 side stand,it also measures 20mm in length and 8mm dia. so what dia is the peg on the rd400 stand please.
the peg on the frame looks like it could be 10mm
Post by stuartadi on Mar 17, 2021 11:04:42 GMT 1
Hi, Have measured the pin on the 400 with a vernier gauge and it is actually 10 mms in diameter. The domed head is 16mms across. The pin on the LC side stand is as you stated is 8mms diameter. Hope this helps?
