Post by buck1963 on Mar 15, 2021 19:49:16 GMT 1
can anybody explain to me how the powervalve controller gets its signal? I've got my zeel wired in as the instructions,when I power the bike up the powervalve goes through its cleaning cycle,I can't run the motor yet as I'm not that far along,the pv controller normally gets it signal from the cdi but now I haven't got a cdi lol,I can't see any connection between the zeel and the pv controller,can anybody enlighten me? Thanks
Post by midlifecrisisrd on Mar 15, 2021 20:32:33 GMT 1
I take it you are using a Zeel that does not do the pv's so you are using the original pv controller
The trigger is the black/yellow wire at the cdi and the pv controller
Post by buck1963 on Mar 15, 2021 21:01:02 GMT 1
I take it you are using a Zeel that does not do the pv's so you are using the original pv controller The trigger is the black/yellow wire at the cdi and the pv controller Steve Thanks for the reply Steve,I'm not very good with wiring but I'm trying to learn,at the moment I have the black/yellow from the servo connected to the black/yellow controller,do I need to piggyback the black/yellow from the zeel into them? And yes mate,your right I have the basic zeel using the original controller
Post by midlifecrisisrd on Mar 15, 2021 21:44:37 GMT 1
The Zeel should have a wire allocated to the pv trigger or pv standard rev counter out put that should connect to the black/yellow wire on the wiring loom on the same block as the orange coil feed
Post by buck1963 on Mar 15, 2021 22:13:17 GMT 1
Thanks again Steve,i haven't got a loom yet as I'm going to do my own,I'm building a lambretta with a 350 motor in it!
