Post by mellow on Mar 15, 2021 10:19:49 GMT 1
Morning men. After a bit of advice/info please. One of the brass/copper tubes that fit into the fuel tap and sit inside the fuel tank is slightly bent on my tap. It has a "slight" kink in it. My question is what is the best option to rectify? heat and try to straighten? replace with new tube if anyone knows where to source the tube or Leave It Alone and use as is? Thanks
Post by Gitram on Mar 15, 2021 10:43:48 GMT 1
could you try pushing a drill bit shank into the hole and giving it a bit of a wiggle to see if it straightens out?
marti
Post by mellow on Mar 15, 2021 10:52:10 GMT 1
I'm not sure🤔 I would have to somehow get the plastic filter off the end of the tube or remove the tube from the tap body. Not sure how or if they even come out. Are they just pushed into the tap body? Anyone know?🤔 I have found some small diameter brass tube now on the interweb. I take it they are brass tubes?
Post by 4l04ever on Mar 15, 2021 11:18:36 GMT 1
Two easiest options are leave as-is, or replace with another one... :-) If LC, the replacements are cheap.
Post by headcoats on Mar 15, 2021 11:37:17 GMT 1
I actually pulled one out attached to the fuel pipe ! , so not that tight
Post by mellow on Mar 15, 2021 11:56:24 GMT 1
you mean the stub the rubber fuel pipe goes onto don't you? I have had that happen too I'm talking about the brass part that sits inside the tank with the mesh filter on
Post by midlifecrisisrd on Mar 15, 2021 12:19:28 GMT 1
What bike?
If you have the non vacuum tap on your ypvs (The one with the filter on the bottom) I'm sure the tube is supposed to be bent
I'd have to check the spare I have
Post by mellow on Mar 15, 2021 12:25:04 GMT 1
It's an F2 but i have bought a 350R one so i can dispense of the vacuum tap If you could check please that would be grand
Post by mellow on Mar 15, 2021 12:28:33 GMT 1
scrub that. a quick google shows it should be bent That's handy and saved some work. Thanks for the replies
Post by midlifecrisisrd on Mar 15, 2021 15:46:50 GMT 1
We've all done stuff like that
Post by Gitram on Mar 15, 2021 16:48:37 GMT 1
🤣🤣🤣 We've all done stuff like that Steve my only comment is no comment.... marti
