Post by milo2811 on Mar 15, 2021 7:44:34 GMT 1
Dear friends, In desperate need for colored wiring diagram for 1983 29L rz250r model. All electric parts are working well however messed up the wiring connections somewhere and hence getting no spark. Or if someone can help me what the numbered connections go to (1 to 9) hoping the others are correct. Thanks a lot in advance. rz250r loom by milind2811, on Flickr
Post by JonW on Mar 15, 2021 8:06:32 GMT 1
To be honest 99% of this is pretty obvious, they will only actually connect to one thing when you get to the place where the wiring ends. Yam did that so people didnt get it wrong.
Kill switch, ign switch are good places to start.
Post by milo2811 on Mar 15, 2021 8:10:26 GMT 1
Issue is most of the sockets on the other parts are open so struggling to match. And I am not so good at electricals:( So if someone can guide using the image i embedded, that would be a boon!
Post by JonW on Mar 15, 2021 8:13:18 GMT 1
The haynes and the OEM manual both have wiring diagrams and you can trace the colours across the plugs... some of those diagrams are online as well.
Ok, that sounds like it may not be what you want either so I'll bow out if what you need is to have someone tell you exactly what to do as I cant do that from here. My advice was about you giving something so you could do it yourself.
Post by milo2811 on Mar 15, 2021 8:24:32 GMT 1
You advice is well appreciated. Unfortunately I did all the wiring myself and its not working. Not a single actual image on the rz250 wiring online though there are tons of others. Anyone with a rz250 or a wiring diagram for the same, pls help
Post by midlifecrisisrd on Mar 15, 2021 9:41:38 GMT 1
FYI the RZ250 29l loom that you have pictured there is virtually identical to the UK 31k LC2 loom from 83/84
Only difference is that it uses a 2 pin flasher relay and does not have the self cancelling indicators
I used one on my spoked hybrid
Post by milo2811 on Mar 15, 2021 16:10:36 GMT 1
Thats helps a great deal Steve. Can this wiring diagram serve the purpose? (picked it up from another thread) 31k by milind2811, on Flickr
Post by midlifecrisisrd on Mar 15, 2021 16:31:15 GMT 1
I don't think so
That one is for the F model so differs around the stator, cdi and kill switch wiring
The wire colours of most things will be the same though
Post by stusco on Mar 15, 2021 17:16:06 GMT 1
Post by shaunthe2nd on Mar 15, 2021 17:21:08 GMT 1
This is an LC2 31k one I am using for my build, may help.
Post by shaunthe2nd on Mar 15, 2021 17:22:34 GMT 1
Snap!
Post by milo2811 on Mar 15, 2021 17:51:24 GMT 1
you are a saviour mate! If possible, please share hi-resol image/pdf..sorry if I am asking too much;)
