Post by daglad on Mar 13, 2021 18:26:38 GMT 1
Hi all, I have just started my powervalve for the first time since rebuild and apart from the usual amount of smoke when l switched it off the carb overflow pipes poured fuel out. I know l need to set the carbs up but l didn't expect that and the amount that came out any thoughts?
Post by shaunthe2nd on Mar 13, 2021 18:39:55 GMT 1
Sticking floats probably. Give the side of carb a good tap with a smaller hammer to see if it reseats.
Post by Tobyjugs on Mar 14, 2021 1:33:24 GMT 1
Could it also be the vacuum tap not working properly?
Post by 4l04ever on Mar 14, 2021 11:03:45 GMT 1
If you run pre-mix, it can also be oil residue in the float valve.
Either way, if it does not sort it self out, just take the carbs apart and clean/check the needle valve and seat are all good and clean.
Post by muttsnuts on Mar 14, 2021 11:27:52 GMT 1
you not got it on prime have you?, if so, switch to ON or RES, if its still weeping (assuming its a vacuum tap type), then your tap is knackered, which PV version is it, as that might help narrow down which type of petrol tap is fitted
Post by daglad on Mar 14, 2021 11:43:09 GMT 1
Thanks guys l am going for another play. I know this will sound stupid but i assume the vacuum pipe just feeds down behind the swing arm and doesn't reconnect somewhere else. Always told there isn't such a thing as a dumb question but l am guessing this is pretty close LOL
Post by buck1963 on Mar 14, 2021 14:20:47 GMT 1
Is it attached to your carb?
Post by daglad on Mar 14, 2021 16:42:08 GMT 1
Its the over flow pipe from the petrol tap. However, i have been playing this afternoon and it seems to have sorted itself out but thanks for all your help guys
Post by midlifecrisisrd on Mar 14, 2021 20:08:09 GMT 1
There is no overflow pipe from the fuel tap Steve
Post by daglad on Mar 17, 2021 20:25:16 GMT 1
Hi Steve, sorry i meant breather pipe
