Post by drc on Mar 12, 2021 2:17:09 GMT 1
I had a problem with my track bike at the end of last year and think I have narrowed it down to the pickup/pulse coil - whatever its called - that gets triggered by the fly wheel.
The stator and rotor are off a 31k and I'm running a PCDI-10VT. A friend has a new pickup for a 1986 Rz350S (Canadian) which I believe is the same as the N2/F2 in Europe. Is it compatible?
TIA
Post by muttsnuts on Mar 14, 2021 11:31:46 GMT 1
um, that's roght on the cross over of the stator/electronic switch over, you'll need to check the resistance and polarity of the pickup, problem being, if your's is faulty, you won't know if the values match as your's will read incorrectly !
Best thing, test yours with a multi-meter and check the readings against what it should be, that will tell you
