Post by mike1972 on Mar 8, 2021 21:09:13 GMT 1
So my v5 for my rs250 chasis arrived at the weekend, so it's time to start the build Need to turn up various spacers for swingarm and shock linkages that are no longer available to buy Ordered all the ally tubing and plating to fabricate the engine cradle and rear mounts The gsxr front end looks like it will fit right in with little effort once the head race bearing arrive Engine will be standard ypvs with 4mm stroked crank and quite a few other mods thumbnail.jpeg by Mike Bowker, on Flickr thumbnail.jpeg-2 by Mike Bowker, on Flickr thumbnail.jpeg-1 by Mike Bowker, on Flickr thumbnail.jpeg-3 by Mike Bowker, on Flickr
Post by andy748 on Mar 8, 2021 22:33:41 GMT 1
Lovely project you've got there, looking forward to this one. Andy.
Post by jessy03 on Mar 9, 2021 7:55:04 GMT 1
Got a cradle here if you need some dimensions or temples to make it easier.
Jess
Post by mike1972 on Mar 9, 2021 20:30:22 GMT 1
Got a cradle here if you need some dimensions or temples to make it easier. Jess A template would be brilliant , would make it a little bit easier , thanks mike
Post by botty on Mar 9, 2021 21:14:39 GMT 1
Pulling up a chair. ๐๐
Looking forward to progress with this one.
Doing similar with an Rgv with 385 motor.
Post by jessy03 on Mar 10, 2021 7:33:52 GMT 1
Jess[/quote]A template would be brilliant , would make it a little bit easier , thanks mike[/quote]
Send me your address and Iโll do a couple of templates. Jess
Post by mike1972 on Mar 10, 2021 20:03:56 GMT 1
Pulling up a chair. ๐๐ Looking forward to progress with this one. Doing similar with an Rgv with 385 motor. That was my original plan, but an rs chasis came up first , just looked through your post, yours looks great so far
Post by 4l04ever on Mar 10, 2021 21:41:57 GMT 1
Myself and my mate are just building Aprilia Hybrids too. I have a Triumph 675R front end for mine. Just waiting for my engine mounting kit to come from Mark Dent.
Post by mike1972 on Mar 10, 2021 21:53:23 GMT 1
Myself and my mate are just building Aprilia Hybrids too. I have a Triumph 675R front end for mine. Just waiting for my engine mounting kit to come from Mark Dent. Thats a great front end to use that will look great , I tried to contact Mark dent to order a kit but no answer to emails or calls so I,ll fabricate it myself , my brothers a coded welder/ fabricator and we have already built a rgv500 and a ns400 motor in a nc30 chasis so decided to do it ourselfs instead of wait for weeks
Post by 4l04ever on Mar 10, 2021 22:01:24 GMT 1
I have had to list the fitting kit in my will, in case I die before it arrives....:-)
Post by mike1972 on Mar 22, 2021 19:48:26 GMT 1
Post by donkeychomp on Mar 22, 2021 22:46:44 GMT 1
This has piqued my curiosity. Always wanted to see this done but the standard 250 engine was pretty powerful. What kind of BHP are you aiming for with the PV lump?
Post by mike1972 on Mar 23, 2021 8:39:10 GMT 1
Should be high 70,s with the work that's being done
Post by 4l04ever on Mar 23, 2021 22:00:46 GMT 1
My mate's 4mm stroker YPVS engine makes 78hp on the local Dynapro dyno, so that gives a rough idea of real world figures :-)
Post by donkeychomp on Mar 23, 2021 22:53:52 GMT 1
Now that's impressive!
Post by mike1972 on Apr 6, 2021 22:05:49 GMT 1
Engine mounts and cradle fitted and welded today ,the spaces to set the chain alignment will be done after powder coating , can start the engine rebuild now the engine is dry fitted 20210406_211513 by Mike Bowker, on Flickr
Post by mike1972 on Apr 6, 2021 22:08:55 GMT 1
Post by donkeychomp on Apr 6, 2021 22:29:33 GMT 1
Some lovely welds there.
Post by 4l04ever on Apr 7, 2021 20:29:49 GMT 1
Nicely done :-)
Post by mike1972 on May 9, 2021 20:45:23 GMT 1
avb
andys vapour blasting
Post by avb on May 15, 2021 21:03:03 GMT 1
fantastic work mike
Post by sidney81 on May 16, 2021 8:44:54 GMT 1
Great work ๐
Post by bigdork on May 17, 2021 0:10:26 GMT 1
These RS build are my favorite. To me they are likely exactly what Yamaha would have done if they continued to build two strokes. The frames are very reminiscent of the delta box even. Thanks!
Post by jon on May 17, 2021 17:42:07 GMT 1
You say the engine will be standard apart from 4mm crank, but why not get the port floors dropped while itโs apart?
My 385 cylinders should be back from Mick next week by the sound of it?
Happy days.
Post by 4l04ever on May 17, 2021 22:07:14 GMT 1
Are you going to centre the engine in the frame? I am aiming to on mine, and will adjust the sprocket offsets to get it lined up.
Post by mike1972 on May 18, 2021 22:56:15 GMT 1
You say the engine will be standard apart from 4mm crank, but why not get the port floors dropped while itโs apart? My 385 cylinders should be back from Mick next week by the sound of it? Happy days. Jon The bores have been rebored .5mm , all porting and power valves matched by mutts Nutts
Post by mike1972 on May 18, 2021 23:05:53 GMT 1
Are you going to centre the engine in the frame? I am aiming to on mine, and will adjust the sprocket offsets to get it lined up. I,m using an 18.6mm offset sprocket , it puts the engine pretty much central
Post by marrcel on May 19, 2021 8:19:34 GMT 1
Just a thought perhaps you can bring the chainline closer to the tire by some hub adjustments. It is always convenient to have non offset stock sprockets.
Post by 4l04ever on May 19, 2021 8:57:08 GMT 1
It would interesting to see what offset other people have used on the front sprocket for this conversion...
Post by 4l04ever on May 19, 2021 8:59:47 GMT 1
The carrier is quite thin, but it maybe possible to mount the sprocket on the inside face if the chain will still clear the tyre. There is a modified sprocket carrier on eBay to work this way. Was adjusted by NK racing.
