Post by mickt1964 on Mar 5, 2021 22:12:57 GMT 1
Anyone got any good tips / products for cleaning the outside of carbs, to spruce them up etc. That doesn't involve blasting etc Cheers Mike
Post by chrisg on Mar 5, 2021 22:57:19 GMT 1
Solvol autosol and a toothbrush works well.
jimmyg
Post by jimmyg on Mar 5, 2021 23:16:21 GMT 1
Carb cleaner and a brush will remove the filth and grim build up, will not do anything for staining though
Post by pedheadfred on Mar 5, 2021 23:32:09 GMT 1
Mr muscle Oven cleaner put them in a bag put in the oven cleaner leave for an hour 😎
Post by headcoats on Mar 6, 2021 9:00:44 GMT 1
Oven cleaner needs using with caution I used it to remove anodising and after about 15 minutes the oven cleaner wants to blacken the alloy
Post by steve63 on Mar 6, 2021 19:57:31 GMT 1
I bought an ultrasonic cleaner. It was only about £40 I think. I've been cleaning a 31k carb this afternoon. The timer only goes up to 5 minutes and only half the carb is submerged at a time but I just keep turning it over and putting it back on. It had about 40 minutes in total probably but there's not a sign of anything on the carb now. I use ultrasonic car cleaning fluid diluted 10/1 with distilled water.
Post by Yogi on Mar 6, 2021 21:04:27 GMT 1
I bought an ultrasonic cleaner. It was only about £40 I think. I've been cleaning a 31k carb this afternoon. The timer only goes up to 5 minutes and only half the carb is submerged at a time but I just keep turning it over and putting it back on. It had about 40 minutes in total probably but there's not a sign of anything on the carb now. I use ultrasonic car cleaning fluid diluted 10/1 with distilled water. I’ve heard of people cutting a plastic bottle up big enough to put a carb in and standing it in the ultrasonic cleaner so you can do the whole carb in one go 👍
Post by midlifecrisisrd on Mar 6, 2021 21:36:10 GMT 1
As Matt says said get a milk carton, cut it big enough for a carb to go in and sit in the US cleaner
Fill the carton with fluid then the US cleaner
The waves pass through the carton the same way they go through the metal tank
Post by dusty350 on Mar 6, 2021 22:46:12 GMT 1
That's how I do mine
Post by huggy76 on Mar 6, 2021 23:03:55 GMT 1
I've never done it but once read an article where James Whitham was saying that he uses alloy wheel cleaner for cleaning the outside of carbs
