Post by stusco on Mar 2, 2021 20:26:50 GMT 1
What about the middle bearings?
Post by pigboy on Mar 2, 2021 20:34:59 GMT 1
It’s for a single piston crank
Post by stusco on Mar 2, 2021 20:36:29 GMT 1
Ahhhh
Post by stusco on Mar 2, 2021 20:37:40 GMT 1
Well the hot n cold method should do it might not be effortless though id be prepared with a suitable dolly just in case
Post by chrisg on Mar 3, 2021 16:30:44 GMT 1
If you can find a tube with an ID slightly bigger that the OD of the crank, it should tap on.
Although if your like me, the tube that would be a perfect fit was the one that you took to the tip last week after tripping on it for the last 5 years.
Post by galant2nz on Mar 3, 2021 19:27:34 GMT 1
Method I used was recommended by a mate that has been playing with smokers for years. Warm up the inner ring and slide them on with the crank cold. Make up a couple of tube spacers and washers so you can use the primary and flywheel nuts to stop them creeping back as they cool. Better still turn up a hat spacer out of mild steel that is a clearance fit inside the bearing with a M8 bolt for a handle fitted to the side of the larger diameter. Place inside the bearing and heat(not too much) remove and slip bearing on. I also used to get a large drill and recess the top side were you heat it from to concentrate the flame away from the bearing.
