Post by mellow on Mar 1, 2021 18:07:54 GMT 1
Afternoon men. Does anyone know of a supplier for the brake caliper slide pins? I've had a trawl of the net but cannot find any Also, when refitting the caliper boot thing onto the slide do you use red rubber grease,copper grease or normal grease please? TIA Mellow
Post by beardy on Mar 1, 2021 20:02:34 GMT 1
Hi. I can’t help with the pins. But I have years of experience with rebuilding callipers. I now use red rubber grease where pins slide in rubber boots. I used to use copper slip and grease but found over time the boots would swell. That’s not to say red grease is the correct grease but it works 👍🏻
Post by mellow on Mar 1, 2021 21:43:10 GMT 1
Cheers bud👍🙂
Post by Tobyjugs on Mar 3, 2021 18:06:32 GMT 1
Another modern suggestion is to use Molykote 111. It really is good stuff. Excellent lubrication properties and perfect for modern rubberware.
Post by LC_BOTT on Mar 4, 2021 9:40:50 GMT 1
Post by mellow on Mar 4, 2021 16:45:58 GMT 1
that set is with the brake pad pin not the slide pin though isn't it?
Post by LC_BOTT on Mar 4, 2021 18:23:34 GMT 1
Yep sorry you're right, don't think I've seen any slide pins either, assume your is missing?
Post by mellow on Mar 4, 2021 21:32:19 GMT 1
No it's there, just a little crusty👍🙂
