smm
Post by smm on Feb 26, 2021 19:27:19 GMT 1
Nipped around the block today on my 350 l, brought it back end of last year so have not ridden it, clutch is slipping when you get high up in the Rev range... time for a new set of plates is there any makes to avoid?? Thanks
Post by Gitram on Feb 26, 2021 19:45:13 GMT 1
have you adjusted the cable, taken the clutch cover off for a quick peek at the plates and are the rubber spacer rings still in situ? if so whip them out and give it another go, might be better..
marti
smm
Post by smm on Feb 26, 2021 19:50:49 GMT 1
Hi Marti No I haven’t had a look.. rubber spacer rings??
Post by Gitram on Feb 26, 2021 20:06:36 GMT 1
aye, there was a half dozen or so in from the factory, I can't remember what they were for but I had some in one of my LC's years ago and the clutch slipped and I was advised to remove them.. the clutch didn't slip after that
marti
