Post by ypvsimon on Feb 21, 2021 22:02:37 GMT 1
Hi All, Will be painting the original factory exhausts soon. What do you guys recommend as best heat resistant satin black paint that looks factory-ish?
Also, the cans have seen better days so may need to be fettled and painted too. Satin silver heat resistant. Again any suggestions gratefully received 👍🙂
Cheers, Simon
Post by geoffers997 on Feb 22, 2021 1:15:00 GMT 1
I got mine done in cerakote. Came up a treat.
Post by mak595 on Feb 22, 2021 6:17:39 GMT 1
I used matt BBQ spray then VHT gloss lacquer and i ended up with a satin finish
Post by ypvsimon on Feb 22, 2021 14:03:08 GMT 1
I got mine done in cerakote. Came up a treat. The cerakote looks great. I understand that to be a heat resistant ceramic coating. May I ask approx how much those cost to cerakote? Pm if like.
Post by kirkhd on Feb 22, 2021 20:15:57 GMT 1
I got mine done in cerakote. Came up a treat. The cerakote looks great. I understand that to be a heat resistant ceramic coating. May I ask approx how much those cost to cerakote? Pm if like. Found this site with prices SMPRO
Post by ypvsimon on Feb 22, 2021 23:36:08 GMT 1
Nice one, many thanks 👍😀
Gord
Post by Gord on Feb 24, 2021 17:52:50 GMT 1
I got mine done at a powder coated who put a ceramic coating on it.
Post by abar121 on Feb 25, 2021 15:41:28 GMT 1
The satin metal protection paint from Lidl (Bauerfix?) is brilliant.
Lovely finish that is petrol resistant and has lasted years on my bikes. Cheap and no need to bake either.
Post by kirkhd on Feb 25, 2021 20:44:28 GMT 1
The satin metal protection paint from Lidl (Bauerfix?) is brilliant. Lovely finish that is petrol resistant and has lasted years on my bikes. Cheap and no need to bake either. Is this rattle can or Brush as got a couple of 31k top cases to paint?
Post by abar121 on Feb 25, 2021 21:01:50 GMT 1
The satin metal protection paint from Lidl (Bauerfix?) is brilliant. Lovely finish that is petrol resistant and has lasted years on my bikes. Cheap and no need to bake either. Is this rattle can or Brush as got a couple of 31k top cases to paint? Rattle can. I've not tried it on cases though. I use Hycote black engine enamel for that and also for frames. Gives a good durable thicker finish.
Post by ypvsimon on Feb 25, 2021 21:09:16 GMT 1
The satin metal protection paint from Lidl (Bauerfix?) is brilliant. Lovely finish that is petrol resistant and has lasted years on my bikes. Cheap and no need to bake either. Thanks,is that paint heat resistant for exhausts?
Post by abar121 on Feb 25, 2021 21:24:38 GMT 1
The satin metal protection paint from Lidl (Bauerfix?) is brilliant. Lovely finish that is petrol resistant and has lasted years on my bikes. Cheap and no need to bake either. Thanks,is that paint heat resistant for exhausts? It's been fine on my stock 31k / 4LO pipes.
Post by kirkhd on Feb 25, 2021 22:01:54 GMT 1
Is this rattle can or Brush as got a couple of 31k top cases to paint? Rattle can. I've not tried it on cases though. I use Hycote black engine enamel for that and also for frames. Gives a good durable thicker finish. Only seams to be Gloss and top engine cases are matt i believe.
Post by pedheadfred on Feb 25, 2021 22:19:26 GMT 1
Plastikote woodstove black 26030 code is satin other one is mat. Good stuff but gets harder with heat about £8:00 a can
Post by ypvsimon on Feb 26, 2021 0:29:57 GMT 1
Plastikote woodstove black 26030 code is satin other one is mat. Good stuff but gets harder with heat about £8:00 a can Looks good stuff, have you used it on exhausts?
Post by pedheadfred on Feb 26, 2021 1:22:34 GMT 1
It's all I use on exhausts most other stuff either don't look right colour wise Finnish. Or it's dull or don't last Rustolium stuff or VHT s like blackboard paint 😵
Post by ypvsimon on Feb 26, 2021 8:55:38 GMT 1
Nice one, many thanks Fred 👍
