Post by rsvr1000 on Feb 21, 2021 21:39:24 GMT 1
Guys I have these 3 springs over at the moment searched all through my pics and cannot see or remember were they are from ? any ideas ? they are small the nut is M6 20210220_105952 by Tony Wall, on Flickr
Post by LC_BOTT on Feb 21, 2021 22:46:22 GMT 1
Footrest springs???
Post by rsvr1000 on Feb 21, 2021 22:56:21 GMT 1
I thought that , in parts manual the rear has 2 funny shaped springs but these are fitted. The front left hand has a return spring this is also fitted. Hence the question nearly all of the passive yellow parts I have used up
Post by mak595 on Feb 22, 2021 6:40:31 GMT 1
Done 2 31k's now (+1 hybrid) and dont recall seeing anything like them.... Reminds me when i worked in a bodyshop, we used to chuck an old 17mm seat belt mount bolt on the apprentices bits tin, then once he built up the car, he would be stuck with this "very important" bolt left over
Post by JonW on Feb 22, 2021 7:31:14 GMT 1
If larger then i would have said they were from inside the Indicators... But at that size im drawing a blank at the mo, especially only 3 of them. not many fixings with only 3... rear light, er.... lol
Post by LC_BOTT on Feb 22, 2021 8:56:36 GMT 1
The three threw me too, did think the footrest spring are wound tighter on one end. Like jon said not many springs on our bikes, did think along same lines.... rear light loom... depends on how far you take things apart
Post by paulsx on Feb 22, 2021 10:16:57 GMT 1
If larger then i would have said they were from inside the Indicators... But at that size im drawing a blank at the mo, especially only 3 of them. not many fixings with only 3... rear light, er.... lol Would have been my guess aswell
Post by rsvr1000 on Feb 22, 2021 10:26:09 GMT 1
The three threw me too, did think the footrest spring are wound tighter on one end. Like jon said not many springs on our bikes, did think along same lines.... rear light loom... depends on how far you take things apart Thanks Guys, this one has me baffled, I did completely strip down the foot pegs for rechroming but cannot for love of money see if I missed these out of the pegs, I did miss the return the spring for the left front peg but I have since sorted this one. I will double check parts manual and the pics I took when I stripped the bike Tony
Post by JonW on Feb 27, 2021 1:40:02 GMT 1
Ive been thinking about this over the days... how about the spring from the inside of the ignition switch? Acts to push the key back up when you engage the steering lock. Its about this shape/coils... but maybe slightly bigger?
lc2
Post by lc2 on Feb 27, 2021 4:55:38 GMT 1
I suspect you have parts from someone else's vehicle accidentally mixed up with yours , not uncommon.
