dezcbr
Post by dezcbr on Feb 20, 2021 19:48:15 GMT 1
Evening, finally got the crank out of my YPVS and it has been very neatly welded on the pins. Does anyone know of a firm that would rebuild it? Or is my only option a new one? Cheers D
Post by headcoats on Feb 20, 2021 19:59:11 GMT 1
I know P J Engineering won't touch a welded crank but they can be repaired
Chris Applebee sorted mine in the end but was quite a few years back
dezcbr
Post by dezcbr on Feb 21, 2021 10:52:31 GMT 1
I know P J Engineering won't touch a welded crank but they can be repaired Chris Applebee sorted mine in the end but was quite a few years back Thanks I will give him a call tomorrow 👍
Post by chrisg on Feb 22, 2021 12:38:28 GMT 1
Post by bare on Feb 22, 2021 20:56:50 GMT 1
Traditionally OEM yama cranks can be repressed 3 x.. 'usually' :-) Many tuners would weld a crank on it's second pressing Or even first..when Extreme use was planned. Some welded Shite/worn out cranks to make them survive a little longer. Alledgedly the welds, if capably done, can be removed and rewelded on reassembly. Problem being; without full history there could be unpleasant surprises on disassembly imo a welded crank is at end of life.. Unless you have 100% certainty that it's only had One prior pressing.
Post by bare on Feb 22, 2021 21:03:17 GMT 1
On that Note 'Vitos' Performance Banshee (etc) Crank assemblies are Best of Breed Aftermarket Cranks, Currently considered superior even to OEM yama ones. Besides being notably Cheaper than OEM (in USA ;-) these feature both Welded AND splined webs.. polished rods, upgraded NTK (japan ) Bearings . Why piss about with back alley repair shops? Food for thought.
Post by steeley on Feb 22, 2021 22:04:45 GMT 1
On that Note 'Vitos' Performance Banshee (etc) Crank assemblies are Best of Breed Aftermarket Cranks, Currently considered superior even to OEM yama ones. Besides being notably Cheaper than OEM (in USA ;-) these feature both Welded AND splined webs.. polished rods, upgraded NTK (japan ) Bearings . Why piss about with back alley repair shops? Food for thought. Interesting , Back alley repair shops .That did make me smile . No , just making an observation .Sid looks to Camera .
