Post by loudy on Feb 19, 2021 20:02:56 GMT 1
Hello All, I'm helping a mate out with his LC and it's wiring issues. When switching on or off the ignition, I can hear and feel the indicator relay click once. There is a black male bullet connector floating about near the relay but not connected to anything. There's no corresponding female nearby. Looking at the wiring diagram, I think the black wire should be connected to the black/yellow wire going to the relay. Is this correct and could this be the reason for the click?? The indicators work fine🤔🥴
Thanks !!
Post by 4l04ever on Feb 19, 2021 20:57:00 GMT 1
The black wire is for European bikes, and is not connected on UK bikes if you have the cancelling unit fitted.
Post by 4l04ever on Feb 19, 2021 21:02:48 GMT 1
If you PM me your email address, I can send you a wiring diagram.
Post by loudy on Feb 19, 2021 21:04:15 GMT 1
The black wire is for European bikes, and is not connected on UK bikes if you have the cancelling unit fitted. Ah, I have a feeling it's an import..it's a mars bar with a silver stripe if that's relevant! I'll find out. Thank you.
Post by 4l04ever on Feb 19, 2021 21:06:34 GMT 1
You need to check if the cancelling unit is fitted under the coil. It is a black rectangular block.
Post by loudy on Feb 19, 2021 21:15:40 GMT 1
The black wire is for European bikes, and is not connected on UK bikes if you have the cancelling unit fitted. Ah, I have a feeling it's an import..it's a mars bar with a silver stripe if that's relevant! I'll find out. Thank you. It's a UK bike without self cancelling indicators.
Post by loudy on Feb 19, 2021 21:38:49 GMT 1
Ah, I have a feeling it's an import..it's a mars bar with a silver stripe if that's relevant! I'll find out. Thank you. It's a UK bike without self cancelling indicators. I lie! I think I can see the cancelling unit behind the head stock. Thanks for your help. Great forum.
