Post by bernardo on Feb 19, 2021 17:10:45 GMT 1
Probably a stupid question but, having dropped one of the main jet washers, can I replace it with another of the same size.
Post by tony2stroke on Feb 19, 2021 17:11:54 GMT 1
Probably a stupid question but, having dropped one of the main jet washers, can I replace it with another of the same size. Norbo sells them.
Post by reedpete on Feb 19, 2021 17:27:10 GMT 1
Probably a stupid question but, having dropped one of the main jet washers, can I replace it with another of the same size. As long as it’s brass and stamped so that it has one sharp edge...but you can’t just use a random steel, washer if that’s what you were asking.. so you do need to go get correct item.
Post by bernardo on Feb 19, 2021 17:52:08 GMT 1
Thanks. That explains my bad running on one side
