Post by kernow on Feb 12, 2021 20:43:31 GMT 1
Looking to replace the front caliper bolts on my R1-Z with stainless steel items. Talking to the team at Powerhouse the threads are 8mm x 1mm pitch unlike the normal 8mm x 1.5 pitch which they do not stock. Has anyone encountered this size or know of a reputable stockist, i would prefer cap head or even button head rather than hexagon if only to match the rest of the bike. Thanks Bry
Post by midlifecrisisrd on Feb 12, 2021 20:49:14 GMT 1
Is it not just m10 x 1.25 like all other caliper mounting bolts?
Post by midlifecrisisrd on Feb 12, 2021 20:50:52 GMT 1
I use these
Post by kernow on Feb 12, 2021 20:55:22 GMT 1
Is it not just m10 x 1.25 like all other caliper mounting bolts? Steve Hello Steve, these are the 8mm bolts to hold the two half's of the calipers together rather than the 10mm fixings to the forks. Thanks Bry
Post by Yogi on Feb 12, 2021 20:57:50 GMT 1
Post by midlifecrisisrd on Feb 12, 2021 21:03:09 GMT 1
Post by midlifecrisisrd on Feb 12, 2021 21:12:59 GMT 1
Post by kernow on Feb 12, 2021 21:41:52 GMT 1
They are 40mm and 45mm long, two of each per caliper. It is an oddball pitch size hence the unavailability by the looks of things. I could have the existing re-plated or leave the originals which in truth are okay but i prefer stainless. Its madness at times, can,t leave bugger all alone. LOL
Post by LC_BOTT on Feb 12, 2021 22:17:32 GMT 1
have you had them out?? i totally stripped mine, but can't remember if there was anything special about the caliper bolts etc? I'll try and have a look tomorrow, but would assume I put the originals back in. Same as FZR250 calipers and other generic ones around at the same time.
Post by kernow on Feb 12, 2021 23:16:10 GMT 1
have you had them out?? i totally stripped mine, but can't remember if there was anything special about the caliper bolts etc? I'll try and have a look tomorrow, but would assume I put the originals back in. Same as FZR250 calipers and other generic ones around at the same time. Yes i took two out (one at a time) to measure the length as i couldn't find any to compare. Powerhouse said the 1mm pitch was rare and only covered a few bikes maybe the FZR250 is one. The good thing is the previous owner had used Copaslip so the removal was easy. Why the use of 1mm pitch who knows .
Post by midlifecrisisrd on Feb 12, 2021 23:42:50 GMT 1
Plenty from Chinky land
expat
Post by expat on Feb 14, 2021 2:45:37 GMT 1
Look at Stig fasteners, they have pretty much anything you will want in stainless which is more than adequate for this job.
