Rob123
Post by Rob123 on Feb 5, 2021 20:35:56 GMT 1
Do you use the copper gaskets and the paper style one at same time. I'm reading not to use the paper style one as it allows the copper one to get crushed more. Any other tips on how you fit yours would be appreciated. The flanges are perfect by the way they don't look like they've been overtightened or had much use to be fair. Cheers Rob
Post by kostas on Feb 7, 2021 19:05:58 GMT 1
It all has to do with the condition of the shims between the exhaust header and the mounting flange. This is what determines how much pressure will actually be applied on the copper gasket.
I would loose the paper gasket gust to be on the safe side.
Kostas
