Post by spudscossiecobra on Feb 5, 2021 20:10:59 GMT 1
Hi all Looking lat building another hybrid and would like to fit fzr400 3jt front and rear ends to my 1ua do they fit think the front end will fit with stem swap but will the swing arm go in or is it to wide Thanks for any advice
stasky
Post by stasky on Feb 5, 2021 23:19:00 GMT 1
swing arm needs width reduced at pivot,its not a straight fit,and its a wide/chunky swing arm,so footrests will deffo need spaced out,shock linkages all need thinking out,i had one fitted with an rgv250 rear wheel,good thing for many is that it retains the standard wheelbase,i think an earlier fzr400 arm would be easier 002 by michael macmillan, on Flickr
Post by midlifecrisisrd on Feb 5, 2021 23:28:28 GMT 1
FZR400 just needs 5mm taken off each side at the pivot then use the 1ua pivot sleeve Couple of tie bars and spacers to connect to the H link Steve
Post by andy748 on Feb 8, 2021 10:22:56 GMT 1
Hi Steve, i have tried to fit a R1-z arm into my N1 and it clouts the frame bracing behind the oil bottle/battery box under compression, it looks a similar shape to yours, does it clear ok? Cheers, Andy.
Post by midlifecrisisrd on Feb 9, 2021 16:51:29 GMT 1
Hi Steve, i have tried to fit a R1-z arm into my N1 and it clouts the frame bracing behind the oil bottle/battery box under compression, it looks a similar shape to yours, does it clear ok? Cheers, Andy. Hi Here's a pic of it before I jacked it up more The frame bar is above the swing arm brace so clears Steve
Post by andy748 on Feb 9, 2021 21:02:42 GMT 1
Yeah, it looks like the bracing on my arm comes a bit further forward than yours, jacking mine up would look odd, yours looks just right. Andy.
