Post by shaunthe2nd on Feb 4, 2021 20:33:19 GMT 1
Just masking up before painting tomorrow.
-is the Engine number normally painted? -do you leave the raised round bits around the numbered screw holes bare for seating of fasteners or not? -I think I read somewhere the casing is low gloss black. Please advise if not asap!
Thanks,Shaun
Post by midlifecrisisrd on Feb 4, 2021 20:40:19 GMT 1
Yes, satin black
Number is painted as is under the washers
Usually not a problem as the washers stop any paint damage
Post by kostas on Feb 4, 2021 20:41:55 GMT 1
Engine numbers are painted Personally I would leave the raised parts unpainted I have seen fasteners loose their torque over time, I did the same with the bottom of the engine.
Kostas
Post by headcoats on Feb 4, 2021 21:50:08 GMT 1
I don't paint mine, I leave bare like an LC, but have to paint strip first !
Unless you want a standard finish
Post by shaunthe2nd on Feb 4, 2021 22:32:43 GMT 1
Yes, satin black Number is painted as is under the washers Usually not a problem as the washers stop any paint damage Steve Is the crankcase normally a bit less shiny than the barrels/head? I've done those in Simoniz engine black gloss and they are quite, err shiny! Had it in my head that the crankcase wasn't as shiny, so I guess that's why you say satin.
Post by shaunthe2nd on Feb 4, 2021 22:35:24 GMT 1
I don't paint mine, I leave bare like an LC, but have to paint strip first ! Unless you want a standard finish I much prefer the bare cases too, especially after they have been vapour blasted, but i'm going stock so they getting painted.
Post by midlifecrisisrd on Feb 4, 2021 22:37:59 GMT 1
Yes
On a 31k I do head, barrels, side cases, Yam disc and oil pump cover in gloss
Top case is not gloss. Satin or low gloss
Some will say the barrels were satin but if you ever see a 31k nos barrel it is more gloss than the 1ua ones
Its just the Simoniz is so feckin shiny 🤣
It does tone down with age lol
Post by shaunthe2nd on Feb 5, 2021 14:26:38 GMT 1
Found half a tin of PJ1 satin black so used that. Its in the oven now. 150 deg for 30 mins.
Post by midlifecrisisrd on Feb 5, 2021 14:33:10 GMT 1
DAD!!!!
Why does dinner taste funny 🤢
Shut up and eat your PJ1 pie 😆
