Post by giggsey999 on Feb 3, 2021 20:26:19 GMT 1
With genuine clocks being very hard to find and extremely expensive if you do find some, has anyone found an alternative set of clocks from another model that are more readily available and not too much trouble to fit and get working?
Post by marrcel on Feb 3, 2021 21:24:02 GMT 1
I hated the drive cables. I wanted to have digital speed display because the radar trapps in NL. So I ordered a cheap china clock. Works for 3 years now.
Post by midlifecrisisrd on Feb 3, 2021 21:30:07 GMT 1
If you can find the 2 clock looms you can use the N model clocks with a bit of soldering 😁 Also very easy with the looms to fit LC clocks Done it loads of times Steve
Post by giggsey999 on Feb 3, 2021 22:07:41 GMT 1
I have the ones in the bottom pic on my lc2 ypvs, not sure if there true to the bike or not, they work fine apart from the low oil light which is on all the time when in neutral, then goes off when you put it in gear, all 3 clocks are good but the body is rough, looks like they have been crashed at some point. Has anyone transplanted their clocks into a different housing from a fzr or fazer maybe.
Post by midlifecrisisrd on Feb 3, 2021 22:12:44 GMT 1
FZR rear case is different I'm afraid
Post by giggsey999 on Feb 3, 2021 23:45:33 GMT 1
Yes I know there different just wondered if it could be done.
Post by julianboolean on Feb 4, 2021 9:17:16 GMT 1
RD125LC Mk3, cost me £60 for the set, they're a bit faded but look okay, you have to drill the mounting bolts out of the mounting frame otherwise they sit too high.
I've been looking for a set of kidney clocks, but you won't get any for under £200, and they'll be tatty at that price.
Post by steve63 on Feb 4, 2021 9:30:52 GMT 1
I have the ones in the bottom pic on my lc2 ypvs, not sure if there true to the bike or not, they work fine apart from the low oil light which is on all the time when in neutral, then goes off when you put it in gear, all 3 clocks are good but the body is rough, looks like they have been crashed at some point. Has anyone transplanted their clocks into a different housing from a fzr or fazer maybe. I think the low oil should be on all the time when the bike is in neutral. It's so you know the bulb hasn't blown.
Post by midlifecrisisrd on Feb 4, 2021 9:43:54 GMT 1
Correct
Lc2 has a 3 wire sender so is triggered when sender says low and when the bike is in neutral as you say to show the bulb works
Later bikes were 2 wire sender so never came on with neutral but would light for a few seconds when switched on then fade out
Annoyingly on these the sender goes duff so the light then fade function stops working even though the float works fine and the lamp still operates when low
Post by giggsey999 on Feb 4, 2021 21:59:28 GMT 1
Yes it has 3 wire sender, light goes off when In gear, not tested the low oil function yet, the tank is nearly full.
