murp
Post by murp on Feb 2, 2021 19:40:41 GMT 1
Any ideas how to get this out.... It's stuck fast and the bearing doesn't seat in it properly.... Cheers
Post by reedpete on Feb 2, 2021 19:51:16 GMT 1
What have you tried already? Just pulling with grips?
I’d be ...
Heat, freeze, PB blaster and tap it around..
If no go, repeat
If seriously no go, worst case scenario... I’d Dremel it into three bits even if t takes a bit of aluminium as it won’t affect fit or function.
Post by stusco on Feb 2, 2021 20:03:09 GMT 1
If it’s fully home why doesn’t the bearing seat properly?
Post by jon on Feb 2, 2021 20:09:12 GMT 1
I think I’d try scoring a very small vee into the aluminium both sides of the c clip, then heat the cases. Use a flat bladed screwdriver as a a drift and tap the end of the clip to try and rotate the clip.
murp
Post by murp on Feb 2, 2021 20:13:03 GMT 1
I can't get grips on it .... I've tried hitting the top edge with a blunt punch.... It's stuck fast
Post by midlifecrisisrd on Feb 2, 2021 20:17:06 GMT 1
Heat the sh1t out of it
There may be some beari g lock in there
Post by JonW on Feb 2, 2021 21:51:15 GMT 1
Heat and drift it from the ends is what i would do.
Post by headcoats on Feb 2, 2021 22:13:47 GMT 1
Has it rusted then expanded ? What about soaking it in some rust eating solution
murp
Post by murp on Feb 2, 2021 22:19:24 GMT 1
Cheers for suggestions.... I've not got it out, but managed to get bearing seated on it finally.... Cheers👍
murp
Post by murp on Feb 3, 2021 0:19:33 GMT 1
The pin was a bit to long👍
Post by marrcel on Feb 3, 2021 8:11:44 GMT 1
Lube it and tap it gently with nylon hammer. Or piece of wood between steel hammer. Then take a flatblade to hit the end of the clip. I think you don’t need heat.
murp
Post by murp on Feb 3, 2021 9:39:46 GMT 1
There's no way this clip is coming out without damage to the crankcase....I think the new bearing pin was a bit too long and lifting the bearing..I've filed a tad off the pin..... The bearing seems to sit in crank ok now..... Does the c clip really need to come out ?
On another note if you look at the picture a previous pin has gouged a groove where it must have spun a bit..... Would appreciate if you think this will cause a problem..... Cheers 👍
Post by LC_BOTT on Feb 3, 2021 9:55:00 GMT 1
Were you fitting the pin into the drilling at the bottom? or into the small cut-out next to the C-clip as shown?
For the 'damaged' bit, just make sure it's nice and smooth with the surrounding surface, you could assemble the cases just to check both faces meet nicely before applying any final sealant.
murp
Post by murp on Feb 3, 2021 9:56:28 GMT 1
Fitting the pin in the small cut out next to the c clip
I didn't know you could use the holes at the bottom
Post by LC_BOTT on Feb 3, 2021 10:41:54 GMT 1
No I've never used the holes either, not even sure what they are there for. Always use the groove/cut-out as you mentioned. I'm sure some of the early bearings had a small ball in the outer race rather than the pin??
Post by midlifecrisisrd on Feb 3, 2021 10:53:07 GMT 1
No I've never used the holes either, not even sure what they are there for. Always use the groove/cut-out as you mentioned. I'm sure some of the early bearings had a small ball in the outer race rather than the pin?? Usually the RH bearing was like that Steve
Post by steeley on Feb 3, 2021 16:43:23 GMT 1
Hmmm, is it just me but i would want to get the c clip out of the case .
