Post by oldelsieboy on Feb 8, 2021 20:38:05 GMT 1
That is the best example of a modified lc I have ever seen, no bling or tat just purposeful, love it. Brilliant, that was my intention OEB
TZ350LC
Feb 15, 2021 22:27:30 GMT 1
Post by archloafer on Feb 15, 2021 22:27:30 GMT 1
Yep, well nice!
What did the dyno say re power output?
TZ350LC
Feb 25, 2021 8:02:20 GMT 1
via mobile
Post by veg on Feb 25, 2021 8:02:20 GMT 1
Totally agree with that last remark, except for Tims bike. Plus no piece of wood under the side stand. Ha no more wood under my side stand I’ve replaced it. Nigel it looks lovely and very nearly what I did spoke wheel wise only to be persuaded by Nk into his mags. What did it put out on the dyno? I’ve still to run mine in and get it back to Dave’s for some of his pipes. What pipes are you running? Real credit to you and thanks for all your help and advice when I built mine 👍
Post by oldelsieboy on Feb 25, 2021 18:14:21 GMT 1
The exhausts are Alonze F2 pipes, the mid range pipes did not work that well & I wasn't going to spend even more cash on a custom set. Dyno output was 58bhp @ 7900rpm with 39.2 ft/lbs of torque at 7700rpm which I am pleased with, was never my intention to built a rev hungry animal. OEB
expat
TZ350LC
Mar 23, 2021 19:28:07 GMT 1
Post by expat on Mar 23, 2021 19:28:07 GMT 1
Nice bike
For a kick start you'd also need the crank cases to have the hole for the shaft to sit in, TZ crank cases might have it, I don't know, but I wouldn't have thought they would.
Looks like a TZ bottom end with LC top end. TZ crankcases are essentially the same as early RD aircooled cases, they have the same castings with a few extra machinings. You are correct, it is a TZ bottom end, the top end is also TZ. OEB I hope it does better than my RS125 GP bike.... HRC recommends new pistons every 350 miles and a crank every 1500... that will get silly expensive on the street!!
dave68
TZ350LC
Mar 30, 2021 17:31:47 GMT 1
Post by dave68 on Mar 30, 2021 17:31:47 GMT 1
Love the wheels great looking bike
Post by oldelsieboy on Apr 27, 2021 20:25:30 GMT 1
Finally got round to fitting the new primary cover so it now has a kickstarter. OEB
TZ350LC
Apr 27, 2021 23:26:56 GMT 1
Post by carioca656 on Apr 27, 2021 23:26:56 GMT 1
where did you get primary cover and how much mate
Post by oldelsieboy on Apr 28, 2021 6:38:44 GMT 1
where did you get primary cover and how much mate Vince at Fondseca gets them made, IIRC it was £450 The clutch guard/cover is not included. OEB
Post by carioca656 on Apr 28, 2021 8:52:17 GMT 1
where did you get primary cover and how much mate Vince at Fondseca gets them made, IIRC it was £450 The clutch guard/cover is not included. OEB thanks mate
TZ350LC
Apr 28, 2021 19:22:36 GMT 1
via mobile
Post by Tobyjugs on Apr 28, 2021 19:22:36 GMT 1
That's nice, also with the optional gear change
