Post by mark69 on Jan 30, 2021 22:16:00 GMT 1
Hi, when people talk about machining the sprocket carrier where is the material being removed from? Also is there a carrier for a TZR that is narrower than a 1KT?
Post by jon on Jan 31, 2021 10:42:02 GMT 1
What people are talking about is taking material of the mounting face of the sprocket to move it inwards.
There’s plenty of meat on a 1WT carrier to do this. From memory my 1WT one had 8mm off? Could have been 5mm?
Post by mark69 on Jan 31, 2021 11:33:40 GMT 1
Thanks jon, do you know if this can be done in a lathe, or does it have to be milled?
Post by jon on Jan 31, 2021 12:01:11 GMT 1
Better in a lathe than milling. Would need a CNC mill and complicated to program. Much quicker and easier in a lathe eithe conventional or CNC.
Did a YPVS one recently in my lathe.
Post by midlifecrisisrd on Jan 31, 2021 12:06:04 GMT 1
The complication of the 1kt one is it has studs in it that would need removed
Post by jon on Jan 31, 2021 12:27:10 GMT 1
Hi Steve they come out easy enough with 2 nuts locked together and a blowtorch.
The studs needs shortening too.
I have one in my LC/TZR hybrid. 3.5” rear wheel with offset front sproket and machined carrier.
Post by mark69 on Jan 31, 2021 18:16:43 GMT 1
Hi Steve they come out easy enough with 2 nuts locked together and a blowtorch. The studs needs shortening too. I have one in my LC/TZR hybrid. 3.5” rear wheel with offset front sproket and machined carrier. Jon Interesting, is it in a standard LC swingarm? Mark.
Post by marrcel on Jan 31, 2021 18:31:13 GMT 1
With stock lc2swinger i put in a belgarda szr660 wheel in. Instead of offset frontsprocket i changed the chain line. This has been done with a lathe.
Post by Tobyjugs on Jan 31, 2021 21:34:51 GMT 1
I did the same as Marrcel to my 4LO. It uses standard front sprocket.
Post by jon on Feb 2, 2021 8:44:41 GMT 1
Hi Steve they come out easy enough with 2 nuts locked together and a blowtorch. The studs needs shortening too. I have one in my LC/TZR hybrid. 3.5” rear wheel with offset front sproket and machined carrier. Jon Interesting, is it in a standard LC swingarm? Mark. No, it’s a TZR 2MA swingarm. Jon
Post by 4l04ever on Feb 2, 2021 19:14:29 GMT 1
I use a 4FL rear wheel with a 1KT sprocket carrier which has been machined down in a standard 4L0 swingarm. I used disk bolts instead of studs and nuts for the sprocket.
Post by jon on Feb 2, 2021 19:49:14 GMT 1
I use a 4FL rear wheel with a 1KT sprocket carrier which has been machined down in a standard 4L0 swingarm. I used disk bolts instead of studs and nuts for the sprocket. From memory mine is a TZR 4DL rear wheel with 1KT machined sprocket carrier, and an offset front sprocket. Jon
