Post by pigboy on Jan 30, 2021 8:44:15 GMT 1
Please could anyone tell me what symptoms you get if the right crankcase seal is leaking , I’ve replaced them with pattern ones and put them in as per Haynes manual which I understand is incorrect
Post by jessy03 on Jan 30, 2021 9:31:15 GMT 1
If it’s the right hand one if will be a bit smoky and use some gearbox oil, plug might be a bit oily as well. Yeah mr Haynes got it the wrong way round should be castlations to the bearing to aid lubrication. No easy fix - cases split and genuine seal
Post by ERic350 on Jan 30, 2021 9:46:55 GMT 1
You are not the first and probably also not the last with the casle-mistery Not sure the direction makes all that difference. Do a leaktest. If there are problems you will find it out that way. See this thread for the castle discussion. rdlccrazy.proboards.com/thread/19185/crankcase-oil-seals
Post by beardy on Jan 30, 2021 10:14:14 GMT 1
Last week I had to change the thermostat on my vw t4 and used the Haynes manual. After topping up the coolant the manual showed a picture with an arrow pointing to the bleed screw at the top of the engine bay. I thought that don’t look right and got my mechanic son to have a look too. It was the clutch bleed nipple. I then looked at the bleeding the clutch section and there was the same picture 🤷♂️ I still always buy a Haines manual though.
Post by dusty350 on Jan 30, 2021 11:37:19 GMT 1
As well as the gear oil level dropping, you may be able to smell petrol in the clutch case if you remove the threaded filler cap. Castellations towards the bearing, always. Seals - pattern can be very iffy, with some failing with less than 1000 miles on them. Genuine Yamaha only with these, in my opinion.
Dusty
Post by pigboy on Jan 31, 2021 13:19:02 GMT 1
This maybe my problem
Post by midlifecrisisrd on Jan 31, 2021 13:34:10 GMT 1
That will do it
Post by headcoats on Jan 31, 2021 13:47:23 GMT 1
Yes needs to be made a "sticky" to only use genuine Yam seals for the crank
Post by jessy03 on Jan 31, 2021 14:20:09 GMT 1
Looks a bit foooked
Are you sure it was a pattern seal, looks like it has reddish coating on one side same as genuine may be SFK?
Does it have ars on it?
Post by dusty350 on Jan 31, 2021 14:29:35 GMT 1
I thought that too Jess. Although some of the copies are very good nowadays, even own to the bags they come in. It does look "pinched" though. Be interested to know the brand and supplier of that crank seal ?
Dusty
Post by pigboy on Jan 31, 2021 14:53:47 GMT 1
So you think pressure could be less as king through here ? Enough to stop right cylinder not working at as all ?
Post by pigboy on Jan 31, 2021 14:55:00 GMT 1
I thought that too Jess. Although some of the copies are very good nowadays, even own to the bags they come in. It does look "pinched" though. Be interested to know the brand and supplier of that crank seal ? Dusty It may be genuine but can find a purchase I did on Fowler’s
Post by jessy03 on Jan 31, 2021 15:00:47 GMT 1
If you got it from Fowler’s then it’s genuine, can’t see how the damage occurred though, you must of damaged it installing it, hard to do though.
Post by headcoats on Jan 31, 2021 15:06:36 GMT 1
Did you oil or grease the lips before instalation
Post by dusty350 on Jan 31, 2021 15:12:55 GMT 1
Yep, if Fowlers then genuine Yam. It looks like physical damage, as opposed to material failure, but as Jess says, hard to do ? Dusty
Post by pigboy on Jan 31, 2021 15:27:43 GMT 1
Did you oil or grease the lips before instalation Don’t think I did
Post by pigboy on Jan 31, 2021 15:28:41 GMT 1
If you got it from Fowler’s then it’s genuine, can’t see how the damage occurred though, you must of damaged it installing it, hard to do though. Yes I’m thinking I did , costly mistake
Post by jessy03 on Jan 31, 2021 15:32:23 GMT 1
Never mind we all make mistakes, at least you know what the problem was.
Jess
Post by pigboy on Feb 10, 2021 17:49:21 GMT 1
All fitted now with a new set of B8RES Sspark plugs and she’s flying ,
