Gord
Post by Gord on Jan 29, 2021 19:31:44 GMT 1
One of the clips on my fuse box is broken. Someone has replaced it with a modified blade connector but it just floats around loose in the box. Looking for a good solution to either fix it or replace it. I don’t see that the fuse box as being available for a 4Lo and it’s wired directly into the loom anyway.
Post by midlifecrisisrd on Jan 29, 2021 20:21:17 GMT 1
Part number 1NL-W8215-00
Gord
Post by Gord on Jan 29, 2021 21:36:59 GMT 1
Part number 1NL-W8215-00 Steve Thank you Steve
Post by bare on Jan 30, 2021 0:34:56 GMT 1
Fuse boxes are available !? I had to buy a handful of Glass type Fuse holders from Mouser (~1$ each ;-) Then cannibalize them for their metal fuse holder tab bits to retrofit into the Old Yama fuse box case. Worked / looked same as OEM
Post by steve h on Jan 30, 2021 1:47:32 GMT 1
Post by brigitte on Jan 30, 2021 9:58:20 GMT 1
Hello,
I have had this happen and soldered the fuse to the remains of the clip. My 4L0 never blew a fuse, so it was a good fix.
Gord
Post by Gord on Jan 31, 2021 15:34:16 GMT 1
Post by beardy on Jan 31, 2021 17:10:22 GMT 1
Not sure if it’s fleabay or shambits but I bought a pattern one for I think an air cooled just to get the clips which I then soldered into my box. Ideally I would have bought the clips but couldn’t find them on the net?
Gord
Post by Gord on Jan 31, 2021 18:33:30 GMT 1
Not sure if it’s fleabay or shambits but I bought a pattern one for I think an air cooled just to get the clips which I then soldered into my box. Ideally I would have bought the clips but couldn’t find them on the net? I ended up finding the clips and only 10usd to ship so now I'm going to look for a replacement for the fuse box itself.
Post by beardy on Jan 31, 2021 19:04:20 GMT 1
Just had a quick butchers on fleabay and this is what I probably bought. It was a while ago. If you were closer I’d have given you the fuse box as I didn’t need it.
Post by beardy on Jan 31, 2021 19:04:46 GMT 1
Post by andy748 on Jan 31, 2021 19:38:07 GMT 1
Is this box the same as a 31k, if so Gord i have one on my parts harness. Andy.
Post by bare on Feb 1, 2021 17:33:34 GMT 1
Gord
Post by Gord on Feb 1, 2021 18:00:03 GMT 1
Is this box the same as a 31k, if so Gord i have one on my parts harness. Andy. I'm not sure if they are the same Andy - I think I'll try ordering one of the ones below from ebay. Thank though
Post by JonW on Feb 10, 2021 23:53:00 GMT 1
Is this box the same as a 31k, if so Gord i have one on my parts harness. Andy. Im 99% sure its the same box Andy.
Post by midlifecrisisrd on Feb 11, 2021 10:15:15 GMT 1
Does the 31k wiring not exit the bottom instead of the side?
They have dried up after yuniparts wound down
I just bought any one I could find and Every time I break a clip just cut one out the donor box and solder it in where needed
Gord
Post by Gord on Feb 11, 2021 15:46:01 GMT 1
I’ve decided to convert it to blade style fuses. I’m having friend 3D print a new base modelled after the original box.
Post by JonW on Feb 11, 2021 22:57:05 GMT 1
I’ve decided to convert it to blade style fuses. I’m having friend 3D print a new base modelled after the original box. I think Alan was looking at doing something like this wasnt he?
Post by JonW on Feb 11, 2021 23:00:35 GMT 1
Does the 31k wiring not exit the bottom instead of the side? Steve Ahh well that would nix that then, maybe thats the 1% I was talking about... Er.... lol. They have dried up after yuniparts wound down I just bought any one I could find and Every time I break a clip just cut one out the donor box and solder it in where needed Steve You can cut them out of old looms as well. Always worth buying up some old Yam looms of the era, doesnt need to be our bikes to get much the same connectors etc
Post by alankelly on Feb 11, 2021 23:03:31 GMT 1
I’ve decided to convert it to blade style fuses. I’m having friend 3D print a new base modelled after the original box. I think Alan was looking at doing something like this wasnt he? Sorry lads this ones a bit delayed Oh if only I had the time☹️☹️ Too many other 3d projects on the go😳😳 Best wishes Al
Gord
Post by Gord on Feb 11, 2021 23:33:12 GMT 1
I think Alan was looking at doing something like this wasnt he? Sorry lads this ones a bit delayed Oh if only I had the time☹️☹️ Too many other 3d projects on the go😳😳 Best wishes Al I'll post pics of it when I get it back.
Gord
Post by Gord on Feb 18, 2021 2:07:23 GMT 1
Here’s the plan for the 3D printed back plate.
Gord
Post by Gord on Feb 27, 2021 16:00:50 GMT 1
Final design with mounting holes for the Hella fuse holder
Gord
Post by Gord on Feb 27, 2021 16:03:38 GMT 1
Printed in Onyx (nylon 6 with chopped carbon fibre with reinforced continuous fibre Kevlar around the holes and outer edges)
Gord
Post by Gord on Feb 27, 2021 16:05:40 GMT 1
Now got to get it mounted on the bike with some kind of strain relief on the cable.
ajh
Post by ajh on Feb 27, 2021 17:19:30 GMT 1
Printed in Onyx (nylon 6 with chopped carbon fibre with reinforced continuous fibre Kevlar around the holes and outer edges) Dont suppose you can print another? Im doing the same and it looks like I even bought the same fusebox as you. When I got round to it, I was going to fabricate bracket out of ali. One of the things I found with the blade fuseboxs were they were a lot deeper so quite tight on the side panel. Does yours work ok?
Gord
Post by Gord on Feb 27, 2021 18:45:57 GMT 1
Printed in Onyx (nylon 6 with chopped carbon fibre with reinforced continuous fibre Kevlar around the holes and outer edges) Dont suppose you can print another? Im doing the same and it looks like I even bought the same fusebox as you. When I got round to it, I was going to fabricate bracket out of ali. One of the things I found with the blade fuseboxs were they were a lot deeper so quite tight on the side panel. Does yours work ok? I haven’t tried it on the bike yet with the side cover on. 🤞 A friend of mine printed it at work as a favour (actually a bottle of rum). Best I could do is try and get you the file. Let me see if it all fits together.
ajh
Post by ajh on Feb 27, 2021 20:24:51 GMT 1
Thanks but I'll try something out of ali. When I measured with the slimmest fusebox I could find, it looked like I would still have to move it off centre on the bracket to get the side panel on)
Post by steeley on Feb 27, 2021 21:09:20 GMT 1
Beware chaps there are folks about ,and i know who say . Only original for us . I did the same sort of modification on an air cooled rd250e and came up against this sort of closed thinking.Good luck with your quest .I have been thinking of doing the same with my lc . Blade fuses are surely more widely available than old fashioned glass ones . If you cant fit the fuse box behind the panel may be under the seat area/ tail light area .
ajh
Post by ajh on Feb 27, 2021 21:13:41 GMT 1
Beware chaps there are folks about ,and i know who say . Only original for us . I did the same sort of modification on an air cooled rd250e and came up against this sort of closed thinking.Good luck with your quest .I have been thinking of doing the same with my lc . Blade fuses are surely more widely available than old fashioned glass ones . If you cant fit the fuse box behind the panel may be under the seat area/ tail light area . Cheers, mines already been modified to have 'loose' blades under the seat so I'm kinda putting it back to having a fusebox. And Ive just had a load of grief with the glass fuse connections on my AC so I see blades as a good upgrade. My LC is never going to be one for the rivet counters!
