murp
Post by murp on Jan 24, 2021 19:03:08 GMT 1
Guys.... Looking for advice.... Started the LC today.... It's not running strong on r/h cylinder and there's a hint of mayonnaise in the r/h exhaust pipe.... Would this be head gasket or maybe something else..... When I drained the coolant there's no oily residue in it, but the trans oil looks a bit strange..... What does everyone think... Cheers 👍 The spark plug on the right is out of that cylinder as well
Post by bare on Jan 24, 2021 19:16:19 GMT 1
Water in the trans could be simply a water pump seal or even the water tube oring. But it could be something else as well. Time to disassemble the engine to see ! Winter and Lockdown makes this a reasonable time to do this G'luck
Post by 29davyt on Jan 25, 2021 14:00:53 GMT 1
Is the bike in a cold / wet environment ? Could simply be condensation in the exhausts ?? Think your trans oil may need further investigation though .
oh ! And have you checked the water level in your radiator ? Has it used any ?
murp
Post by murp on Jan 25, 2021 22:49:01 GMT 1
I dismantled the engine today... First time ever..... Not too difficult, but there appears to be foam (bubbles) in the trans oil..... Don't know if it's the seal or the o ring, both appear ok, but I will change them and the crank seals anyway...... My dilemma is how do I know if the crank needs a recon and a rebore too..... Don't want to do these jobs if really not necessary.... I need someone to cast an eye over them to see if they are serviceable..... I'm near Basildon Essex....cheers 👍
YZR654
Post by YZR654 on Jan 26, 2021 1:02:02 GMT 1
try Chris Appleby he is very near you near Raleigh 01268 776642 ne is one of the best around i have allways used him
Post by liffy16 on Jan 26, 2021 10:57:58 GMT 1
Could of been o ring on coolant pipe which goes into top crankcase from water pump, does not explain milk in the exhaust though? So if engine sounded ok mechanical a full seal,gasket change would be ok.
Post by marrcel on Jan 26, 2021 18:25:50 GMT 1
I think the only way to get transoil in your exhaust is a leak crankseal.
