Post by russie on Jan 24, 2021 12:07:44 GMT 1
To those that have done this, where did you get a longer 12mm swing arm bolt? Or did you do something different? Thanks in advance. Russ.
ahthud
Post by ahthud on Jan 24, 2021 20:30:03 GMT 1
You can just have the bolt head reduced in depth (spindle side) on the YZF spindle.
ahthud
Post by ahthud on Jan 24, 2021 20:32:34 GMT 1
If you pm me a number or email I'll send you a pic to show what I mean.
Post by mak595 on Jan 24, 2021 23:23:50 GMT 1
I used the original, just machined off the shoulder/washer from the bolt in my lathe so it sits flush with the frame, the frame lug stops it spinning...
Post by russie on Jan 26, 2021 22:44:41 GMT 1
Could have sworn someone posted a response about retaining the original 31K swing arm bolt. Have I dreamt that! 😂
Post by veg on Jan 26, 2021 22:57:58 GMT 1
They did and talked about different bushes and 70bhp it’s now gone 😵
Post by russie on Jan 26, 2021 23:30:31 GMT 1
I do feel that a 12mm swing arm bolt seems like a weakness?
Post by Bobthebuilder on Jan 27, 2021 7:34:52 GMT 1
It was me who put on about the bush’s ive used the original 16mm spindle bronze bush’s and a silver steel sleeve this was because I didn’t fancy 70 plus bhp through a 12mm axle
