Rob123
Post by Rob123 on Jan 22, 2021 17:52:15 GMT 1
Rob123
Post by Rob123 on Jan 22, 2021 18:31:58 GMT 1
Looking forward to trying the ypvs as ive only driven an lc.
Rob123
Post by Rob123 on Jan 22, 2021 18:42:55 GMT 1
Can anyone comment on how the stock f2 exhausts perform? Similar to stock 31k ? They look more expansion chamber design i wondered if they perform different. Cheers Rob 🙂
Post by 123 on Jan 22, 2021 19:25:41 GMT 1
Nice work sofare
Rob123
Post by Rob123 on Jan 26, 2021 18:33:42 GMT 1
Rob123
Post by Rob123 on Jan 26, 2021 18:36:35 GMT 1
Rob123
Post by Rob123 on Jan 26, 2021 18:39:18 GMT 1
Rob123
Post by Rob123 on Jan 26, 2021 19:00:50 GMT 1
I also fitted tacho drive to this engine as I'm going to use it in the lc2 with mechanical tacho. It is a 1986 engine so came blanked off. The complete 350lc tacho drive is what I fitted And Is exactly same as the lc2 one. Also the barrels have had a fresh rebore 1.50mm They have been ported in the past so I'm intrigued to see how it runs. I'll be getting it on the dyno once all finished 👍
Rob123
Post by Rob123 on Jan 30, 2021 20:30:50 GMT 1
Abit more progress top end fitted, clocks, switch gear, grips, its starting to take shape 👍. A have a question about the clocks if anyone knows. The needles are a different colour speedo is white and others are yellow im suspecting a different speedo was fitted from original. Are the white ones just faded yellow ones? Or did they come with white and yellow? Cheers Rob
Post by lc350pete on Jan 31, 2021 12:29:58 GMT 1
Looking really good am doing mine as well
Rob123
Post by Rob123 on Jan 31, 2021 15:29:02 GMT 1
Ah good stuff there seems to be a few lc2's getting done at the minute i am realy enjoying seeing it come to life.😀
Rob123
Post by Rob123 on Jan 31, 2021 15:44:32 GMT 1
Post by lc350pete on Feb 1, 2021 9:41:18 GMT 1
Post by mak595 on Feb 1, 2021 21:14:09 GMT 1
Be running by weekend
Post by shaunthe2nd on Feb 1, 2021 21:24:36 GMT 1
Great progress on that LC2. I'm a bit behind you with my build. What paint have you used on the crankcase and barrels?
Post by rsvr1000 on Feb 1, 2021 22:15:20 GMT 1
Looking Good , put some pics up when you are routing the cables please, need to make sure mine are correct
Rob123
Post by Rob123 on Feb 1, 2021 22:33:06 GMT 1
It won't be far off I wouldn't of thought maybe weekend after 👍. The paint was simoniz gloss engine enamel. Pre heated oven to 120 degrees left it in for 30 mins then cranked it to 180 for 20mins. Total oven time 50mins. Did all my other bits in simoniz satin tough and baked them the same. Deffo worth baking it in my opinion goes like powdercoat. The calipers withstood brake fluid on them although I soon wiped it off and was dot 5. Cheers Rob 🙂
Rob123
Post by Rob123 on Feb 1, 2021 22:37:58 GMT 1
Oven needs a clean 😄
Rob123
Post by Rob123 on Feb 1, 2021 22:39:11 GMT 1
Looking Good , put some pics up when you are routing the cables please, need to make sure mine are correct Was hoping to copy you 😂
Rob123
Post by Rob123 on Feb 2, 2021 20:59:04 GMT 1
Exhaust hangers are next to spruce up, I tried getting the lacquer off with the wire wheel but it was taking forever so grabbed some paint stripper and it removed it in seconds. I will finish them off on scotch bright wheel. I'm tempted to use some of this paint stripper on my plastics that I'm having ago at plastic welding to remove all paint before I start. I don't want them melting away tho. Also I bought some vinyl paint and im going to have ago at spraying my seat. There are no rips anywhere just imperfections here and there that will not scrub off. Too good to recover but not good enough compared to the rest of the bike. Will post up results 👍🙂
Rob123
Post by Rob123 on Feb 4, 2021 13:12:41 GMT 1
Update on the seats i decided to just spray one for now plus the other one doesn't seem that bad now after I gave it another clean. It sprayed on realy good, giving it just a light dusting and working upto a heavier coat. Vital you start very light or it will not adhere properly. Well it looks good for now but time will tell if it holds up. Before & after Side by side pics
Post by shaunthe2nd on Feb 4, 2021 15:03:28 GMT 1
Looks impressive. I wonder how it looks after a few hours in the saddle. Fingers crossed, but don't wear your best jeans on first ride lol
Rob123
Post by Rob123 on Feb 4, 2021 15:29:40 GMT 1
I'm never going to sit on it just hover 1cm above it 😂🤞
Rob123
Post by Rob123 on Feb 5, 2021 19:56:34 GMT 1
Post by rsvr1000 on Feb 5, 2021 21:35:56 GMT 1
Coming on nicely 👍
Rob123
Post by Rob123 on Feb 6, 2021 14:44:54 GMT 1
Rob123
Post by Rob123 on Feb 6, 2021 18:49:57 GMT 1
Post by rsvr1000 on Feb 6, 2021 19:13:14 GMT 1
wow , pipes looks mega
Rob123
Post by Rob123 on Feb 6, 2021 19:16:30 GMT 1
Thanks bud i was lucky they were in good nick to start with. I am realy chuffed how they've turned out 😁
Post by lc350pete on Feb 7, 2021 9:58:16 GMT 1
Looks superb 👍
