Gord
Post by Gord on Jan 22, 2021 16:17:57 GMT 1
I need some help getting the rear wheel back together. The mechanic who straightened the wheel out for me took it apart and I don’t have any photos of what’s what. I’m not sure if this spacer with the flange fitting goes in the centre of the hub between the bearings? And this is the more embarrassing question - this spacer was in the box with the wheel parts and I honestly have no idea where it goes. (I’m hoping it’s from the wheel!!) it’s 25mm ID and 3mm thick. Any help would be appreciated!!
Post by oldelsieboy on Jan 22, 2021 16:37:19 GMT 1
I need some help getting the rear wheel back together. The mechanic who straightened the wheel out for me took it apart and I don’t have any photos of what’s what. I’m not sure if this spacer with the flange fitting goes in the centre of the hub between the bearings? And this is the more embarrassing question - this spacer was in the box with the wheel parts and I honestly have no idea where it goes. (I’m hoping it’s from the wheel!!) it’s 25mm ID and 3mm thick. Any help would be appreciated!! Yes the spacer goes between the bearings. The washer is not part of the rear wheel, looks a lot like a clutch assembly thrust washer. OEB
Post by lcmarky on Jan 22, 2021 16:40:08 GMT 1
The washer might be aftermarket if the spindle has been replaced and is a little long..
Gord
Post by Gord on Jan 22, 2021 17:52:07 GMT 1
I need some help getting the rear wheel back together. The mechanic who straightened the wheel out for me took it apart and I don’t have any photos of what’s what. I’m not sure if this spacer with the flange fitting goes in the centre of the hub between the bearings? And this is the more embarrassing question - this spacer was in the box with the wheel parts and I honestly have no idea where it goes. (I’m hoping it’s from the wheel!!) it’s 25mm ID and 3mm thick. Any help would be appreciated!! Yes the spacer goes between the bearings. The washer is not part of the rear wheel, looks a lot like a clutch assembly thrust washer. OEB Thanks for this - I just took the clutch apart to confirm. The good news is you are right and it is a thrust washer, and both of them were already installed. So now I have a mystery as I have no idea where it came from. Highly unlikely the same part is used else where on the bike?
Post by JonW on Jan 22, 2021 22:58:05 GMT 1
I am missing a clutch washer, how the hell did it get to Gord's place?
Post by 29davyt on Jan 22, 2021 23:16:28 GMT 1
Gord
Post by Gord on Jan 27, 2021 14:25:40 GMT 1
I am missing a clutch washer, how the hell did it get to Gord's place? So that’s where it came from!! Lol
Gord
Post by Gord on Jan 27, 2021 14:26:41 GMT 1
Thanks!! I’ve been using the drawing on the CMS site - this one is way clearer!!
