Rob123
Post by Rob123 on Jan 22, 2021 15:42:25 GMT 1
Can anyone confirm that the seals are the same size for the front and rear calipers. Ive just received an order for some and the rear seals they have sent are alot bigger than the fronts. Just need to double check I haven't got an odd rear caliper on the bike. The seals that I've stripped off are all the same size front and rear they are same size pistons Although the fronts thinner seal is slightly thicker than the rears. Cheers Rob
Rob123
Post by Rob123 on Jan 22, 2021 17:17:13 GMT 1
I have just checked online and I have the correct calipers which both use 38mm seals/pistons.
Only other thing thats concerning me is that the outer thinner seal they've sent is thinner than what was in and doesn't fill the groove in the caliper.
Has anyone had this before? I Should of paid extra for powerhouse ones 🙄
Post by Shytalk on Jan 22, 2021 17:52:12 GMT 1
The rear caliper you have is the correct one for the LC2, those seals are incorrect. The outer seal is essentially a dust seal, who did you get them from? Powerhouse are usually decent quality as are the originals although more costly.
Rob123
Post by Rob123 on Jan 22, 2021 18:27:06 GMT 1
Yer I gathered there incorrect now the rear seals they've sent are 44mm id. Ive contacted them to let them know. There off ebay both front and rears from AW Motorcycles. I'd bought enough to do 2 sets of calipers but I'm going to use the other fronts in the rears until the send me the correct ones. With them just been dust seals I'm going to stick them in altho there abit thin and put plenty of grease around them 👍
