Post by marrcel on Jan 21, 2021 16:57:22 GMT 1
As shown in picture. I looked at Norbos site and shamebits. I couldn’t find it.
Post by midlifecrisisrd on Jan 21, 2021 17:03:35 GMT 1
Part number 99530-10114-00
Post by stusco on Jan 21, 2021 17:28:28 GMT 1
Someone has been at those barrels with a grinder 😁
Post by marrcel on Jan 21, 2021 18:36:57 GMT 1
Part number 99530-10114-00 Steve Thx i googled it and an outboard center could sent it to me👍
Post by marrcel on Jan 21, 2021 18:39:01 GMT 1
Someone has been at those barrels with a grinder 😁 Wrong it was a dremmel😉 It is flush with barrels. I am happy.
Post by jon on Jan 24, 2021 11:51:31 GMT 1
Beware of this part, I bought one and it was next to useless so went in the bin.
I think maybe the original is put in before the stud at the factory. The replacements have to be 8mm+ I.D. to go over the threads, but the waste at the bottom of the stud is smaller. From memory they were even too small O.D.
In the end I made my own on the lathe. The correct O.D. on the outside, and threaded the I.D. so it screwed to the bottom but gripped the waist.
Post by jon on Jan 24, 2021 11:53:05 GMT 1
I’m still plucking up the courage to match my transfers.
I reakon the cases would be around 2mm thick in places after doing this.
Do you know how thick yours are now?
Post by Tobyjugs on Jan 24, 2021 12:22:06 GMT 1
I got some from Norbo, i might still have one i will take a look for you.
Post by midlifecrisisrd on Jan 24, 2021 13:14:28 GMT 1
I’m still plucking up the courage to match my transfers. I reakon the cases would be around 2mm thick in places after doing this. Do you know how thick yours are now? Jon Hi Jon Crap pic but you can see mine here If you are concerned you could use a smear of 3 bond on the gaskets to stick them in place A Siamese gasket from Rob will help the centre. You could also epoxy the bit at the front for support Steve
Post by marrcel on Jan 25, 2021 21:56:50 GMT 1
2mm? no a lot more. But there seems to be more taken away then Steve’s.
Post by jon on Jan 30, 2021 11:07:01 GMT 1
marrcel I know there is far more than 2mm on the gasket face, but I’m on about the wall thickness below the gasket face. Jon
Post by JonW on Jan 31, 2021 23:14:32 GMT 1
Ive done plenty of the matching and never had an issue Jon. Im not sure where you are seeing the 2mm thickness, most of these crankcases are much thicker than that in this area when done. That said you may need (want) to use angles and not just go straight down etc. But thats also about flow as well as removing the restriction.
Post by jon on Feb 1, 2021 6:17:02 GMT 1
JonW I know they are much thicker than 2mm to start with, but I’m on about after matching. Jon
Post by JonW on Feb 1, 2021 7:32:59 GMT 1
JonW I know they are much thicker than 2mm to start with, but I’m on about after matching. Jon Yep I got that, just not sure where would take away so much material it was so thin is all.
Post by marrcel on Feb 1, 2021 10:37:27 GMT 1
marrcel I know there is far more than 2mm on the gasket face, but I’m on about the wall thickness below the gasket face. Jon This is about 9mm. Is this you wanted to know see pic?
